Old 12-26-2012, 10:25 AM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Scion FRS Bespoke Backup Camera, What do I need?
I've read every damn backup camera thread on here and haven't pieced together what I need to get this working with the OEM BeSpoke head unit. There was a thread many months ago and a vendor was selling a kit that was plug and play with the bespoke.
I don't care about the BRZ stuff since that appears to be a completely different pinout since the headunit is different.
Is anyone running a backup camera on their FRS (NOT BRZ)? If so can you post pictures, model numbers, anything?
Maybe I missed a thread but I feel like I searched for everything and have come up empty handed.
post_break is offline   Reply With Quote
Old 12-28-2012, 12:45 AM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Interested myself.
Old 12-28-2012, 01:12 AM   #3
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
I used a Boyo VTB123HD camera on mine, for the camera connection into the factory loom plug I found that the instrument cluster terminals from a ZZE122 corolla are the same size/style so I grabbed a couple of the cluster plugs from a car at the wreckers.
I modified the RCA cable that came with the camera to replace the RCA plug with two of the corolla cluster plug terminals, then clipped those into the factory 86 headunit loom plug.
My factory headunit only puts out 6V for the camera power, so I also used a mini relay to switch in ignition 12V for the boyo camera, triggered by the headunit 6V wire.
JP is offline   Reply With Quote
Old 12-28-2012, 10:15 AM   #4
post_break
post_break's Avatar
Do you have any pictures of it in action?
Old 12-28-2012, 05:56 PM   #5
JP
Backyard Fabricator
here's some pics...
Camera out of the box:
Camera installed on rear trim:
installed on car:
I utilised the stock trunk lid loom plug for the camera wires too. This plug takes the standard sumitomo terminals used in the majority of late toyota engine bay sensor plugs, available from Ballenger motorsports, Phoenix Tuning etc http://www.bmotorsports.com/shop/pro...oducts_id/1567 :
Mini Relay with two terminals soldered on that clip into the headunit's camera power positions, one of the larger red wires is tapped into the headunit ignition switched 12V wire, the other larger red wire runs to the camera:
Completed body-side loom ready to install:
Loom installed in-car:
video from camera:
The lines on that screen are the default ones from the actual BOYO camera. To get the headunit's built-in lines I need to use the other rear camera input on the back of the headunit and cut the blue wire on the boyo loom to disable the boyo's own lines.
Old 09-10-2014, 09:00 PM   #6
darcy011
Drives: Scion TC
Adapter needed
Hello,
It makes a while you have posted this message. Hoping this will help you if you didn't install yet a back-up camera. I've made an installation this week on my Scion TC of a back-up camera and it works good. The Pioneer audio system is compatible to display the image.
However you need an adaptor (72 $ US) to plug behind the system. Here's the link to buy it. http://www.beatsonicusa.com/bcus3-536.html
Good luck!
darcy011 is offline   Reply With Quote
Old 09-11-2014, 12:10 AM   #7
NIN69
Izzy Gure (Senior Member)
NIN69's Avatar
Drives: FR-S TRD Release Series 1.0 / #1459
PM BeatSonic. I have their front and rear camera installed on my FRS. Great customer service and no drilling on the install.
Visit me on Facebook:
http://www.facebook.com/izzygure
NIN69 is offline   Reply With Quote
Old 09-14-2014, 09:22 PM   #8
greencounty
greencounty's Avatar
I used the adapter sold here:
http://www.autoharnesshouse.com/19867.html
It has the relay pre-wired to the harness and it's a bit cheaper.
btw...this is a really old thread. I think there are some pretty good tutorials on this forum for how to do this install now.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
Old 07-02-2016, 09:55 PM   #9
ls1ac
ls1ac's Avatar
If you would like very inexpensive transmit to phone, you could try 4Ucam. I have one but use it only once in a while.
BRZ Backup Cameras- a List TSY Electronics | Audio | NAV | Infotainment 44 11-16-2016 08:06 PM
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 01:18 PM
Beatsonic license plate mounted backup camera? normancw Electronics | Audio | NAV | Infotainment 3 01-28-2013 05:08 PM
anyone interested in a bespoke unit w reverse camera? xpicer NY / NJ / CT / PA 3 11-03-2012 06:57 AM
Scion FRS / BRZ Rear Camera Installed SpecPer Electronics | Audio | NAV | Infotainment 30 09-05-2012 10:37 PM
