Old 06-06-2013, 04:18 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
18x7.5 +48/18x8 +43 staggered or 18x8 +43 square?
I'm considering getting new wheels. I have two options for sizing:
1. Square 18x8 +43
2. Staggered 18x7.5 +48/18x8 +43
How our rear fenders jut out a bit further than the front bugs me a little and the staggered setup helps that by pushing the rear wheels 11.35mm further out than the fronts. But the 18x7.5 +48 fronts will look more sunken in if staggered compared to 18x8 +43 square. Opinions? I'm not concerned about the ability to rotate tires and prefer no spacers.
Old 06-06-2013, 11:09 PM   #2
djdnz
1337
Drives: 2013 BRZ WRB S/C
1. Square 18x8 +43
Well you pretty much answered your own question. The staggered would tend to give you some understeer, if that's alright with you (unless you are running same tires front and back - on a 0.5" difference I think you'd get away with it). IMO I'd go square, and if the rears looked wrong I'd go the spacer route.
djdnz is offline   Reply With Quote
Old 06-08-2013, 02:22 PM   #3
switchlanez
Thanks for the suggestion. I also realized I can get a square setup with square tires and still make the fitment to the fenders look even between front and back by using camber bolts up front. Did some geometry calculations and -1.5 degree camber will tilt the top of my front tires roughly -8mm in.
Old 06-08-2013, 02:25 PM   #4
#87
I usually post drunk
#87's Avatar
Why stagger like that? Go square with narrow wheels. Stagger if you want flush front and rear.
#87 is offline   Reply With Quote
Old 06-08-2013, 02:56 PM   #5
switchlanez
Are you questioning my idea to camber the front? If so, like I said, it's so I can even out the front fitment with the rear, which bugs me a little. And I'd still be running a completely square setup.
And I changed my mind about getting the 18x8 +43 wheels (Prodive GC-07J face style was not what I thought).
Whatever I do get will be square with negative front camber, pretty sure.
Wheel Directory: Rota G-Force 18x8.5 +48 / 18x9.0 +35 Sheldon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 03-13-2014 08:23 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
17X9 SQUARE OR 18X8.5F AND 18X9.5R DAN_BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-03-2013 01:33 PM
NC: Rota MXR Staggered 18x8.5/9.5 FR-S86 Wheels and Tires 12 03-18-2013 01:37 AM
