Old 05-26-2013, 02:14 AM   #1
wootwoot
Drives: FRS
Rear Toe Advice
I plan on installing ground-control coilovers and dropping the car an inch at the MOST. I am hoping to get about -1.5 camber in the rear using the whiteline upper control arm bushings. I am not sure how to adjust the toe, however. I know there is an eccentric bolt on the stock toe arm, but will there be enough adjustment to get my toe back to zero with my marginal drop? Or should I get an adjustable toe arm? Would it be wise to install the powerflex toe arm bushing? And does it provide additional adjustment?
Thanks guys!
wootwoot is offline   Reply With Quote
The Following User Says Thank You to wootwoot For This Useful Post:
Mgivens (05-26-2013)
Old 05-26-2013, 02:53 AM   #2
Mgivens
Drives: Fr-s MT Ultramarine
Don't want to sidetrack your thread, but how did you end up with the ground control setup? ( did you do the basic street or the whole package with camber plates and such)? I am looking at GC and a few other options and am interest in why you made the choice. Sorry I can't help you with your alignment problem
Mgivens is offline   Reply With Quote
Old 05-26-2013, 02:58 AM   #3
D1cker
Drives: B9 S4/ND2
you will have plenty of toe adjustment with the OEM arm.
D1cker is offline   Reply With Quote
Old 05-26-2013, 11:30 AM   #4
wootwoot
Drives: FRS
What other systems are you looking at?
Old 05-26-2013, 11:44 AM   #5
wootwoot
Drives: FRS
Thanks for the advice. I think I'll just put in the powerflex toe bushing and call it a day.
Old 05-26-2013, 03:55 PM   #6
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
you'll be fine with the stock toe adjustment range, i'm 1.4 inches lower and there was enough range to get back in spec.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 05-27-2013, 02:19 AM   #7
Xauterus
Drives: GTS 86 Galaxy Blue
Mine was lowered just 30mm with Cusco lower arms and I ran out of toe adjustment on one side of the car. The toe changes remarkably over that much drop. See how it aligns and add the toe arms later if needed.
Xauterus is offline   Reply With Quote
Old 05-27-2013, 09:23 AM   #8
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I just put in a set of springs and LCA's. just about an inch drop. I couldn't get the passenger side toe set with factory toe adjustment. Looking to get the SPC toe link or may install their toe bushing.
FRSFirestorm is offline   Reply With Quote
Some advice zoomzoomers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-22-2013 05:16 PM
2nd car advice zygrene Other Vehicles & General Automotive Discussions 38 02-19-2013 10:29 PM
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 03:11 PM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 12:17 AM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 05:39 PM
