Old 05-15-2013, 08:24 AM   #1
frosty86
frosty86's Avatar
Drives: '13 FR-S (Whiteout) Manual
Question Transmission
Not sure if this issue was already posted but I think I got a problem with the transmission.
Sometimes the gear won't go in at all and sometimes the gears would slightly grind when i shift in at certain speeds. And no, i don't shift into first gear like a retard at times that i shouldn't be doing it. I make sure that i always push the clutch 100% during my shifts, yet it happens. Not sure what I can do about it really. Am I goin crazy or are there other FRS/BRZ's with similar transmission issues?
frosty86 is offline   Reply With Quote
Old 05-15-2013, 08:49 AM   #2
whaap
whaap's Avatar
If you're driving the car in a normal manner and it won't go into gear, yes there's something wrong. Your car has a warranty, get it to the dealership.
whaap is offline   Reply With Quote
Old 05-15-2013, 01:10 PM   #3
FRiSson
Drives: FR-S MT
Is it a gear grinding - where you can feel the teeth of the gear skipping? Or is it metallic resistance and clunking? The former is a serious problem. The latter is pretty typical of the FR-Z gearbox.
FRiSson is offline   Reply With Quote
Old 05-15-2013, 01:22 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Sometimes, the gear won't go in at all into the 1st gear. I need to let go the clutch once. This happens maybe once a month.
Sometimes, the gears would slightly grind when i shift into the 2nd gear. This happens when I shift the shifter too slowly.
But these happened with all the other cars I had, so I'm not worried. Other than these, mine shifts smoothly with no weird thing.
Sigh-on-Rice is offline   Reply With Quote
Old 05-15-2013, 03:23 PM   #5
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
THis is exactly what happens to me. It's not often but sometimes it does. Even when the clutch is depressed 100%.
CamryDS is offline   Reply With Quote
Old 05-16-2013, 09:00 AM   #6
Mikem53
Drives: FR-S 6MT
I have the same issues u mentioned.. And have had them in other cars as well..
Sometimes thing don't line up in the transmission.. Keeping it simple here.. So you have to let the clutch out which spins everything and your not blocked out of 1st anymore.. 2nd gear syncros are slow to spin up.. Especially when cold.. But as you get more miles on it.. Things loosen up and fall in place smoothly..
The internals are still tight.. And take time to loosen up..
Mikem53 is offline   Reply With Quote
Old 05-16-2013, 11:09 AM   #7
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
My second gear do the same when the car is cold. Just does not force and let the gear go smoothly.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 05-16-2013, 02:15 PM   #8
gily25
Drives: Silica BRZ 6MT
Are you making regular back and forths between the FRS and another vehicle? If you've learned to compensate for an older vehicle or heavier vehicle it can effect your driving style.
gily25 is offline   Reply With Quote
Transmission Echo Engine, Exhaust, Transmission 6 08-08-2012 01:38 AM
What transmission? Ess Vee Engine, Exhaust, Transmission 9 06-25-2012 02:56 PM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
