Old 05-14-2013, 01:57 AM   #1
Someguyk
Someguyk's Avatar
300 watts RMS enough for a sub?
I am looking to add a sub woofer to my FRS OEM system...for now. I plan on going with a single 10in in a sealed box, .75cu of space. I've been shopping around online but before I commit and purchase I was hoping some others could chime in. I'm just looking for bass/lows that I can feel/hear well enough without distorting the music or being insanely loud. I'm hoping 300 watts RMS should be enough and if anyone has thoughts on certain products would be great. Been out the sound game for awhile now. Thanks!!
2013 AT FRS...Stock... for now...
Someguyk is offline   Reply With Quote
Old 05-14-2013, 03:29 AM   #2
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
300wrms is plenty for a single sub to compliment music. After hearing my girlfriends 8" 250wrms slimline unit, I struggle to see why you would need anything else.
Gir is offline   Reply With Quote
Old 05-14-2013, 03:35 AM   #3
ft_sjo
Drives: GT86
Depends on several factors, mainly around driver efficiency and enclosure design. Assuming the latter will be optimal for the particular sub, perceived loudness of a sub can vary by a factor of 400% or more with the same power depending on efficiency.
Back in the old days it was all about high efficiency drivers, low xmax and large/ideal enclosures. I've still got some 15" subs which are 94dB efficient, and are only rated at 300W RMS but will be louder than the modern day equivalent which will have maybe 20mm xmax, only 86dB efficienct and burning up 1kw or so.
Bottom line is.. pick a sub and get an appropriate amp for it. Don't under-power a sub and this will most likely lead you down a bad path of clipping and the impending doom of burnt voice coilsl
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
Redmist (05-14-2013), Skywgn1 (05-17-2013)
Old 05-14-2013, 03:47 AM   #4
Gir
Gir's Avatar
How can under powering a sub hurt it? People say this, but it makes no sense.
Old 05-14-2013, 04:02 AM   #5
ft_sjo
Drives: GT86
Because such folk tend to run the amp into distortion/clip.
The Following User Says Thank You to ft_sjo For This Useful Post:
Sbeezy (05-14-2013)
Old 05-14-2013, 04:33 AM   #6
cruzinbill
Drives: Argento 6spd FR-S
You cant hurt a sub by underpowering it..... as for 300w being enough, yes it should be as long as the sub is rated for that as well. Also make sure the box for the sub is actually correct for it.
A proper tuned ported box is still gonna get more for your money out of 300w tho. But if you want sealed thats fine as well, just dont choke the sub down.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
Sbeezy (05-14-2013)
Old 05-14-2013, 04:40 AM   #7
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Get a pwk design and those 300 watts will serve you well!
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 05-14-2013, 05:00 AM   #8
Gir
Gir's Avatar
I always go for sealed box. They always sound much better then even the best ported boxes. Porting just makes the sub make way more noise, at the cost of quality.
Old 05-14-2013, 05:25 AM   #9
ft_sjo
Drives: GT86
A 300W amp for a 300W sub does not make a good match.
BTW, thanks for completely ignoring me about that MiniDSP.
Old 05-14-2013, 09:05 AM   #10
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Speakers (voice coil) don't like low frequency square waves with a high amplitude.
Gary in NJ is offline   Reply With Quote
Old 05-14-2013, 09:11 AM   #11
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
I've got about 1200w RMS and I must admit, it sounds DAM good at low volumes where there's a just a hint of bass. 300w RMS is more than enough for this car.
Unless you're a bass head ...so it probably also depends what you're coming from. It's similar to a turbo - car's slow, you want a turbo, you get it, your car feels super fast, then after a while you want MOAR POWER! I like having the extra power there so I can still hear the bass driving on the highway with the windows down.
rmjjensen is offline   Reply With Quote
Old 05-14-2013, 10:45 AM   #12
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
www.crutchfield.com They are your friends. The heaven of audio.. Call their hotline or chat with them online for any questions. There customer service is amazing, best service I ever dealed with. I can't wait until they update their products to the BRZ/FRS because I still can't find matching audio products that will be vehicle specific.
Brands I like are JL Audio and Rockford Fosgate I feel their products are high quality and look really nice compared to others.
Marcoscrdo is offline   Reply With Quote
Old 05-14-2013, 12:11 PM   #13
Someguyk
Someguyk's Avatar
Thanks for the quick responses! I'm currently looking at the following for the box, sub and amp. Anyone got advice as too if this will be a decent setup. I've looked at the specs and everything seems to fall into place. Thanks again!
Sealed box-
http://www.integrityconcepts.net/frs...rder-sale.html
Sub-
http://www.crutchfield.com/p_107DXI1...11#details-tab
Amp-
http://www.crutchfield.com/p_130GMD9...34#details-tab
Old 05-14-2013, 12:28 PM   #14
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
depends on the sub but most have rms ratings between 250-400rms.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
---Autolismo.com, Vancouver Canada--- Cree 25+50 Watts LED Reverse Light autolismo Exterior Parts - Lighting 310 11-18-2017 12:42 PM
Where to find Low Wattage HID Kits? (10/15/25 watts) cdo221 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-27-2013 11:57 PM
Merrick Watts reviews the Car of the Year davey90 AUSTRALIA 20 01-01-2013 09:10 PM
This is what 40,000 watts of bass do to your head ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 9 08-23-2011 04:01 PM
