Old 05-13-2013, 12:31 PM   #1
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Race Harness.
I'm thinking of mounting a harness for use in the occasional track day as i do move in the cabin a lot with the stock seat belt.
Mounting points would be the 2 in the rear seat (the child ones afaik) and the bolts that hold the stock seatbelt on either side of the drivers seat.
Am i missing anything here?
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 05-13-2013, 02:13 PM   #2
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I'm not an expert in mounting harnesses, but I wouldn't mount belts to the hooks for the child seats, I think they're really only rated up to 65 lbs or so. When you take the seats off and see them, you'll see how thin they are. Normally you would install a harness bar, or have the belts mounted to the rear seat belt holes.
PERRIN_Chris is offline   Reply With Quote
Old 05-13-2013, 03:13 PM   #3
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
My recommendation is to invest in a harness bar. It's pretty straightforward to install, not hard to remove, and will look better. Most importantly it's designed for these stresses.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 05-13-2013, 03:24 PM   #4
CaptainSlow
CaptainSlow's Avatar
Not to sound like a **** here, but don't get a harness unless you need one. Just my 2 cents. The stock seats are still very supportive even with only the stock seatbelt. Unless you're sliding out of your seat, there really isn't much of a point in upgrading to a harness. Again, just my advice. In the end do what you want
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 05-13-2013, 03:28 PM   #5
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
I'm a bit of a big guy so i do slide out in hard corners, I'm doing my first track day this weekend so ill see how bad it is on a track.
Alright harness bar sounds like the way to go i guess.
Build thread
Old 05-13-2013, 03:41 PM   #6
kevman_101
Drives: 2013 Scion FRS
Get in the car, snug yourself as tight inside the seat as possible, maybe even recline the seat back a slight bit, or back the seat 1 or 2 notches. After this, grab the seat belt and get it really tight up on your shoulders and then give it a quick pull and lock it. It should be pretty tight, but moving the seat forwards again and/or lifting the seat back will get the looseness out of it. You`re now pretty locked in the seat. There will be a bit of movement, but having the seat belt locked should let your arms relax under braking and still hold you pretty good in turns too.
kevman_101 is offline   Reply With Quote
The Following User Says Thank You to kevman_101 For This Useful Post:
CaptainSlow (05-13-2013)
Old 05-13-2013, 05:17 PM   #7
Tainen
Drives: First SWP BRZ-L
Do *not* get a harness without a harness bar. The harnesses are specifically designed to operate at a 90 degree angle, so the belt needs to go straight back from the seat. Additionally, I'd stay away from 4 point harnesses- they struggle in protecting against submarining, which can kill very easily.
Generally I've heard this advise:
1) Stay completely stock, with airbags, belts, seats, everything
2) Go full on safety aftermarket- wheel, seat, 5 or 6 point harness, harness bar/rollcage.
The "in between" setups are usually the most dangerous of all, and most of the deaths that I've seen come from those poorly done halfway implementations.
The stock setup is extremely safe and good. Don't mess with it, unless you are actually going to improve it all the way.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following 2 Users Say Thank You to Tainen For This Useful Post:
Hardrock4445 (05-13-2013), strat61caster (05-13-2013)
Old 05-13-2013, 07:13 PM   #8
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
I agree as this is what I've heard from racing outfits as well. On a track, do it right or don't do it at all.
That being said, I do plan to run a Schroth 4 point anchored to the rear belt receivers for autocross while retaining my factory belts for all other driving. It gives a lot of the benefit with less of the hassle than a full safety rig, and for driving around some cones in an empty parking lot: I'm not too worried about flipping the car.
Re_Invention is offline   Reply With Quote
Old 05-13-2013, 07:19 PM   #9
Mitch
form follows function
Drives: RIP '13 BRZ
Different means to the same end, he could buy a CG-Lock.
Mitch is offline   Reply With Quote
Old 05-13-2013, 08:34 PM   #10
root
Drives: Raven FR-S
I do they poor mans CG lock, twist seatbelt at the buckle.
The child restraint are NOT strong enough, it's expressly stated in Scroths documentation. If I were buying & putting one in I'd get the Scroths. One of few (only?) approved for street use. One shoulder strap is designed to give in a hard impact so it'll act more like the standard three point and reduce chance of submarining. Shoulder straps will probably be attaching at the lower rear seatbelt points, I'm pretty sure the FRS seats are strong enough for this, the seats I recall are approved for certain race sanctioning. The rear seats are kind of close though so the angle might start getting too steep for safety. I actually haven't checked, has Scroths listed the FRS/BRZ yet?
root is offline   Reply With Quote
The Following User Says Thank You to root For This Useful Post:
HotLeopardMama (07-22-2013)
Old 05-13-2013, 09:08 PM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Dont get a harness bar, those things are a fake. Iv seen harness bars bend when people get into rear and side crashes causing slack and making the person slam into the steering wheel (responded to a few calls and seen them in person.) I would either buy a roll cage or a full cage, but I would never buy a plain old harness bar. Or you can buy a roll cage and a harness bar if the roll cage doesn't have a place to hold the harness straps. Also spend the extra money on a 5 point harness, with a 4 point you can slip under the harness.
Here are 2 great roll cages with harness bar setup
http://battleversion.com/store/fr-s-12/
http://www.frsport.com/Cusco-D1-Roll...Z_p_32841.html
I would buy something like this
Avoid something like this
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 05-13-2013, 09:16 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Harness bars are evil. People keep saying different things but the only things I know for sure is that a full set of safety gear gets the most votes and stock gets tons of safety testing.
Old 05-13-2013, 09:21 PM   #13
rapid
Drives: 2010 Mustang GT , Miata
Look at the Schroth 3 point systems. For autocross and occasional track day they are very good.
rapid is offline   Reply With Quote
Old 05-13-2013, 09:22 PM   #14
WolfsFang
Scrape Master
WolfsFang's Avatar
Originally Posted by jsimon7777 View Post
A harness bar isn't a roll cage. Not sure why you would expect it to be. People keep saying different things but the only things I know for sure is that a full set of safety gear gets the most votes and stock gets tons of safety testing.
who ever said a harness bar is a roll cage? there are many roll cages that have a straight bar right behind the seats for a racing harness setup. You either go all out on safety or you dont do it at all, safety is the most important thing.
The Following User Says Thank You to WolfsFang For This Useful Post:
EAGLE5 (05-14-2013)
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 02:15 PM
Race Harness with stock seats Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-06-2013 04:25 PM
FR-S BESPOKE Harness Blake Electronics | Audio | NAV | Infotainment 4 02-04-2013 05:48 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 05:42 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 09:51 PM
