Old 01-28-2013, 12:52 PM   #1
Blake
Drives: Ravin Scion FR-S
FR-S BESPOKE Harness
I know this has been posted somehwere before, but I can't find where. I ordered a Boyo backup camera but need to know where I can buy the proper harness, so I can use the BESPOKE radio screen to display for my back up camera. Does anyone know what harness I need, or where I can get it???
Blake is offline   Reply With Quote
Old 01-29-2013, 04:04 PM   #2
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Two FRS owners with the BeSpoke just received harnesses I sent them. I'd like to hear confirmation from them that everything goes OK, but I'm all but certain that my harness will work without any problems.
The BeSpoke needs a 16-pin plug with the camera RCA jack on pins 8 (signal) and 16 (ground/shield). It does not need anything on pin 15 (just another ground). Since your car has no factory 16-pin harness, you don't need the parking brake signal (pin 6), but I can include a wire for that, if you want to experiment with video playback and adding video to the aux input.
You'll also need to add a wire to the factory 28-pin harness with the reverse gear signal (which your car's harness lacks).
Also see this post.
SVXdc is offline   Reply With Quote
Old 01-31-2013, 06:49 PM   #3
Blake
Also see this post.
Great, let me know if it works. If so let me know what I need to do to order one from you. I already have the back up camera, just need to install it.
Old 01-31-2013, 07:09 PM   #4
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Also see this post.
Any chance for a bespoke DIY?
lbroskee is offline   Reply With Quote
Old 02-04-2013, 04:48 PM   #5
Blake
If you could point me in the direction of getting the harness that would be great. I have a BOYO VTL400SR. Just need the harness to hook it up to the BeSpoke.
Essex Harness Bar: Now Available! JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-26-2018 09:15 AM
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 01:15 PM
Essex Harness Bar: Now Available! JRitt Tracking / Autocross / HPDE / Drifting 23 03-04-2013 12:36 PM
Lighting Harness wawro569 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-09-2012 11:28 AM
ECU Extension Harness available Ishii Motors Engine, Exhaust, Bolt-Ons 2 06-07-2012 03:20 PM
