Old 05-09-2013, 07:45 PM   #1
bcmakesiteasy
Drives: 2013 FRS Ultramarine
what to add on to my muffler delete
disclaimer: I'm a complete noob when it comes to cars. (i was quite proud when i installed my muffler delete myself )
Hey Guys,
So I have the berk dual exit muffler delete on my FRS and I wanted to get some aftermarket exhaust parts. I can't for the life of me figure out where a cat pipe/front pipe etc would connect to my muffler delete. I would assume its the midpipe? Where would a downpipe connect to? here is the diagram i've been looking at to figure out how all this stuff works. Any recommendations are welcome...i would prefer a piece with a resonator as my muffler delete's drone is almost unbearable at the moment.
bcmakesiteasy is offline   Reply With Quote
Old 05-09-2013, 07:47 PM   #2
NickFRS
Drives: 2013 Asphalt FRS
Well you removed the part of the exhaust that brings down the DB level and doesn't change power gains that much. Should of got some mufflers and a header w/cat delete. Would of still been loud and made more power... Your in for a world of rasp n exhaust tickets.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-09-2013, 08:17 PM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Congratz on your install thats a great feeling !
your next step could be a drop in and search for a Midpipe( i don't know many companies that make them.)
After that add a HiFlow front pipe or a Catless Front pipe (depending on preference on how loud & Raspy)
after that go for a tune and you'd be set for a while
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
bcmakesiteasy (05-10-2013)
Old 05-09-2013, 08:19 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Berk is modular so it will bolt on to aftermarket pieces
Correct you will need a midpipe.
I think we are the only one that makes a midpipe
Only way to lessen the drone is to add a resonator to your berk.
Or change them to these muffler deletes
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Old 05-09-2013, 08:37 PM   #5
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
@86_ZN6 nice looking products you got there. any pics of the "muffler deletes" mounted to show fitment with the rear bumper?
@bcmakesiteasy congrats on your install. always good feeling to do your own work, u bond with your car
SLICVIC is offline   Reply With Quote
The Following 2 Users Say Thank You to SLICVIC For This Useful Post:
6-Shift (05-10-2013), bcmakesiteasy (05-10-2013)
Old 05-09-2013, 09:05 PM   #6
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
ARK performance has a midpipe and front pipe if im not mistaken
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 05-10-2013, 03:24 AM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
there's a lot of pics and vids on the development thread
---> http://www.ft86club.com/forums/showthread.php?t=24472
SLICVIC (05-10-2013)
Old 05-10-2013, 03:46 AM   #8
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
What you're thinking of is the front pipe, which is the part after the header and overpipe. An aftermarket over pipe and front pipe with a resonator or high flow cat would give you essentially a header back exhaust. The mid pipe doesn't make a huge difference (from what I've seen) but if you have the money...SMS has a good point, a drop in air filter from K&N, HKS, Perrin, Works, or Zeta would give you a little more power too for cheap.
TL;DR: spend your money on drop in air filter, over pipe, and front pipe. I believe Nameless has an Over pipe/front pipe combo which would be a great option too. Good luck
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 05-10-2013, 05:50 AM   #9
SmsAlSuwaidi
Boosted
A nameless over/front pipe combo is the way to go actually good suggestion
Old 05-10-2013, 02:04 PM   #10
bcmakesiteasy
thanks everybody for the help! So essentially what i'm getting from everybody is that the midpipe doesn't offer much HP gains and there arent that many options available to swap it out. So when companies like nameless, berk, invidia etc mention a cat delete or catted pipe they mean its a replacement for the front pipe? I'm thinking of leaving the midpipe, customizing my muffler delete by adding a resonator to it, and replacing the front pipe/over pipe. Also keep in mind I have an AT...does that limit my options? Are these aftermarket front pipes compatible for both transmissions?
From what i've been reading here on the forums, members are saying that intake's aren't worth the cost per HP gains...I was thinking of just getting a a drop in filter from K&N (which I can get for a discount because my buddy is a sales rep there). Thoughts?
Old 05-10-2013, 02:17 PM   #11
SmsAlSuwaidi
Boosted
If I'm correct nameless offers their front/over combo for AT's but remember installation is a bit painful with the requirement of lifting the engine.
Regarding the intake, get that k&n without even thinking about it
Old 05-10-2013, 03:14 PM   #12
CaptainSlow
CaptainSlow's Avatar
What resonator would you all recommend for this application? I am getting the Berk muffler delete as well, and I was just wondering in case I decide to go the resonator route to keep the drone down...I really don't even know where to start (like what size, length, ID, manufacturer, etc)
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 05-10-2013, 03:21 PM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
we use 18 inch resonators on our exhaust sytems
CaptainSlow (05-10-2013)
Old 05-12-2013, 03:50 PM   #14
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
This is the setup I'm going for on my FRS.. I think it sounds absolutely awesome and would cost less that 500 shipped
[ame="https://www.youtube.com/watch?v=C5JB_m2BLJg&feature=youtube_gdata_player"]BRZ/FR-S Berk Exhaust Sound Clips (Camera on car) - YouTube[/ame]
Sent from my Galaxy S4 using Tapatalk 2
MooKz is offline   Reply With Quote
The Following User Says Thank You to MooKz For This Useful Post:
dokterdewe (05-14-2013)
Muffler Delete SkitterSkotter Engine, Exhaust, Transmission 37 07-04-2017 01:44 AM
Does anyone have Mach V muffler delete? ScionFrsFan Engine, Exhaust, Transmission 24 09-18-2014 08:05 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 06:09 PM
Muffler delete zooplane Engine, Exhaust, Transmission 11 12-16-2012 08:00 PM
Dual Muffler Delete by F.M.S fmsida Engine, Exhaust, Transmission 2 10-19-2012 09:37 AM
