Old 05-08-2013, 10:55 AM   #1
FA20Club.com
Drives: 2013 White Out FR-S
FA20CLUB Oil Cooler Kit Released....
We havent had much time with other projects to post this but seeing as we have already sold a few of them I should inform the public of its availability. The kits was built an test with out turbo kit so im sure it will work with most other kits on the market. Since everyone has their own preference on mounting locations for their cooler I just wanted to show how we setup our car. I routed the lines as short as possible to minimized pressure drop and mounted the unit directly behind the fog light bezel incase I wanted to open it up for direct airflow. You can also mount it in front of the AC condensor since we supply long enough lines to do so which can be shorted to do the install pictures. The provides the ease of install for different applications. We have never been keen on one size fits all approach and always like to provide options With that in mond the kits will ship with either Mocal, Mishimoto or Setrab coolers. We are also including a thermostat based oil filter adapter to ensure your engine gets up to temp as always.
Base Price starting @$549.00 Shipped
FA20Club.com is offline
Old 05-08-2013, 11:03 AM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Can't see where it's mounted in the last pic. Can you supply some more detailed mounting pics for that location?
For mounting in front of the AC condenser, do you provide mounts or "feet" for the cooler?
Price looks good. I'm interested!
ATL BRZ is offline
Old 05-08-2013, 12:41 PM   #3
FA20Club.com
are you intending to mount it in the same location cause that was really allocated for those with turbo kits. NA cars would be best suited to mount up from using our universal mounts
Old 05-08-2013, 01:29 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Won't work with the Full Blown kit.
King Tut is offline
Old 05-08-2013, 01:36 PM   #5
ATL BRZ
ATL BRZ's Avatar
No I wasn't intending to mount it there, I was just curious.
I'd like to see how the universal mounts look with the cooler mounted in front of the AC condenser.
I'm assuming drilling a few holes in the plastic under tray is required?
ATL BRZ is offline
Old 05-08-2013, 03:46 PM   #6
FA20Club.com
actually it will cause we allow enough hose in the kit to mount it anywhere you want with about 3 different bracket setup. I tested the cooler mouning location on FRS300 car yesterday and it will fit the same location with a shortercore right about the hot side charge pipe or infront of the intercooler with the larger core
Old 05-08-2013, 03:46 PM   #7
FA20Club.com
you are correct in your assumption on the small holes
Old 05-08-2013, 04:11 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Pictures with the washer bottle in place?
King Tut is offline
Old 05-08-2013, 06:48 PM   #9
Burn
Slack Bum
Burn's Avatar
Does the adapter allows fitting of 2 oil sensors ?
Burn is offline
Old 05-08-2013, 08:49 PM   #10
FA20Club.com
its aluminum so it can be tapped for pressure sensors easily or external temp sensors.
Old 05-08-2013, 09:11 PM   #11
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
+1
AJ PwR is offline
Old 05-08-2013, 09:47 PM   #12
FA20Club.com
ill see about that next week
Old 05-08-2013, 11:06 PM   #13
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
looks like a nice kit. i should get it and mount it outside the bumper. old school 86 style lol
IG-Joey_Soul
Grip Ronin is offline
Old 05-09-2013, 07:27 AM   #14
mad_sb
Drives: 2013 Asphalt FR-S
Nice, i will be in touch to order soon
mad_sb is offline
NEW FBM Oil Cooler Kit $595 Shipped! FullBlown Forced Induction 114 11-14-2019 11:28 AM
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
