Old 05-05-2013, 09:15 PM   #1
86ft.lb
86ft.lb's Avatar
Drives: orange fr-s MT
Brake pad changing tip: effortless piston retreat with techstream
1. Goal
Retreat piston so that new pad can fit in the caliper.
2. Requirements
Techstream (toyota scan program), cable, and laptop
3. Procedure
Connect to vehicle. Select ABS module. Select active test menu. There are total 12 solenoids. 4 of them are pressure release solenoid. Select one of them and start a test. The test will activate the solenoid for 2 secs and pressure will be released, making piston retreat.
SRLR = Solenoid Rear Left Release
SRRR = Solenoid Rear Right Release
SFLR = Solenoid Front Left Release
SFRR = Solenoid Front Right Release
4. Pros and cons
Pros: No C-clamp or brute force required. No need to bleed air even though pressure is released.
Cons: laptop, cable, and program required.
Happy braking!
86ft.lb is offline   Reply With Quote
Old 06-07-2013, 11:20 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Anyone can confirm this works?
Old 06-07-2013, 01:10 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd rather just use a c clamp, not that I can these days anyways (up front anyways). A c clamp is going to be quicker IMO than dealing with a laptap.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-07-2013, 01:23 PM   #4
SkullWorks
Drives: SSM LT MT BRZ
I can confirm that those are options in the Techstream active tests and that they last ~2seconds,
I cannot confirm that they retract (because i haven't tried)
I can confirm also that the logic behind the acronym makes more sense than what i was guessing at when I was playing with it last night...
SkullWorks is offline   Reply With Quote
Old 06-07-2013, 01:59 PM   #5
OrbitalEllipses
Drives: Attitude
Yes, but when you're doing a pad change you want to crack the bleeder and push that old fluid out and replace it with fresh fluid, instead of pushing it back into the lines/reservoir and using it again.
I just use the old pad, placed on the piston, and pull it into the caliper from the other side, one hand on each "dog ear" of the pad.
Old 06-07-2013, 03:23 PM   #6
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
I've never done it this way. I admit I don't always bleed my brakes when I put in new pads. It would work just fine, but I don't always have a helping hand around to help with the brake bleed.
GTM_Challenge is offline   Reply With Quote
Old 06-07-2013, 07:03 PM   #7
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
What he said. The worst fluid in the system is the burned stuff in the caliper, why would you want to force that back into the lines?
celica73 is offline   Reply With Quote
Old 06-07-2013, 07:12 PM   #8
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
im sorry but i must be informed on why you need to bleed your brakes when you change pads? really doesnt make since to me since the system has not been opened in any way?
alex_86 is offline   Reply With Quote
Old 06-07-2013, 07:31 PM   #9
OrbitalEllipses
Drives: Attitude
The post above yours dude....
Toyota TechStream Ver GTS_10.10.018 - Diagnostic Tools for FR-S/GT86/BRZ Trap63 Scion FR-S / Toyota 86 GT86 General Forum 225 03-09-2024 03:53 AM
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Using higher quality brake fluid vs using cheap but changing more often ayau Tracking / Autocross / HPDE / Drifting 41 06-14-2015 01:20 PM
Introducing: AP Racing Six Piston, 14 inch Formula Road Brake Kit JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 01-23-2013 04:18 PM
Brake piston sizes coyote Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-25-2012 05:51 PM
