Old 05-02-2013, 11:09 PM   #1
stanm
stanm's Avatar
Drives: 2013 Asphalt FR-S 6MT
Parking lights don't work
Not sure if I am using the right term. The lights that turn on when you switch the headlight stalk to the first notch.
I went on a track day, then at night, noticed the parking lights don't turn on at all (rear brakes, turn signals in the fronts that light up dim).
If I hit the brakes, use the turn signal, those lights work just fine, but the dimmer setting is not working.
A couple people suggested it is likely a fuse problem, any idea which fuse I need to check?
Thanks guys, much appreciated
stanm is offline   Reply With Quote
Old 05-03-2013, 09:38 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if fuse was blown, light won't turn on at all. sounds like something is not right. i would visit dealer. electrical stuff is complicated
Old 05-05-2013, 05:37 PM   #3
DaBlKSupaMn
Drives: Firestorm Red FRS
mine only turn on with the ebrake released....
DaBlKSupaMn is offline   Reply With Quote
Old 05-05-2013, 05:45 PM   #4
zc06_kisstherain
Drives: SWP BRZ
That is normal
Sent from my Galaxy Nexus using Tapatalk 2
Old 05-05-2013, 07:07 PM   #5
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Originally Posted by zc06_kisstherain View Post
That is normal
YES!
Deepseadiver is offline   Reply With Quote
Old 05-05-2013, 07:08 PM   #6
Deepseadiver
YES, lights on only when parking break is released!
Old 05-05-2013, 08:38 PM   #7
Sacs
Drives: GT86
Err, doesn't that defeat the purpose of PARKING lights? I usually have the parking brake ON when I'm parked.
And when in a poorly lit street would expect to be able to turn the parking lights on to provide some visibility.
Sacs is offline   Reply With Quote
Old 05-05-2013, 11:21 PM   #8
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
It is a bit weird, I also wished the C-band light would be on with the DRLs, would look really nice. But they only turn on when e-brake is up or something?
Myv is offline   Reply With Quote
Old 05-07-2013, 07:24 PM   #9
stanm
stanm's Avatar
Brought it to the dealer this morning
Turns out one of the fuse was blown (tail light fuse under driver steering column) :/
Side markers & parking lights don't work Cajun Cosmetic Modification (Interior/Exterior/Lighting) 20 05-28-2015 04:28 PM
Parking lot behind my work - Dubai RevoG ASIA 8 03-18-2013 09:32 AM
Changing parking lights to white LED bulbs JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 11 03-13-2013 03:38 AM
FR-S & 370z @ My work parking lot francosolracer Scion FR-S / Toyota 86 GT86 General Forum 10 07-04-2012 06:25 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
