Drives: Scion FR-S Whiteout
Shifting problems?
I have a manual FR-S, with these issues:
1. Shifting into first gear (from neutral at 0mph or from higher gears at less than 10mph) produces a *thud* sound and very slightly jerks the car a little. I supposed this is the clutch connecting the engine to the wheels, but is it really that noticeable? This happens 50% of the time, and usually when the RPM is decreasing. 2. Shifting from 1st to 2nd gear produces a metallic clunk (not grind). It doesn't sound that bad, more like when cocking a gun, you can hear the gears "meshing" together. Is this normal? Only on 1st to 2nd gear. 3. Are the shift points that low or am I just not getting it? Whenever speeding up (to merge into a freeway from a stop), when I'm upshifting, I get a thud and a jerk. I usually upshifts at 2.5-3K RPM or every 15mph. I let go of the clutch pedal quickly because I don't want to burn out the clutch early. Is this wrong? Should I be letting the clutch go slowly? |
Drives: American Made Shift!
How many miles on the car? If its still pretty new, it will be a little clunky till things wear in.
#3 | |
Drives: 2003 Camry Blue | 2013 FR-S White
3 points in the clutch A - << clutch depressed | | | B - << biting point | | | C - << Fully engaged clutch You can let go of the clutch however fast you want from point A to point B -- but you gotta hold your foot on point B until your tach/revs match to a point where it's smooth -- then slowly disengage to C You slowly move from A to C and you'll get a hesitation all the time, no matter how slow -- sometimes you may get lucky, but doing it this way is wrong and you'll screw up the clutch. Hope that explains things =) -- Oh your throw-out-bearing will always be under wear when you depress the clutch, so you gotta keep that in mind. Clunk will be there for a while, as long as you're not grinding -- no problems. When in doubt, let go of the clutch and then depress the clutch all the way down and try again to engage the gear. Last edited by CamryDS; 05-02-2013 at 03:53 PM. Reason: grammar =/ |
All relatively normal, see if you can meetup with another owner and listen to his/her car, or maybe go to the dealer and speak with them.
You can let the clutch out slower to help smooth out the ride, yes it may increase wear but that is it's job, to wear and smooth the transmission of power to the wheels. It's replaceable and this car is so simple that it shouldn't be a big deal. |
Drives: Attitude
Clunky clutch and 2nd gear shift have been there since day 1 for me.
Scheduled a service visit when shift quality started to degrade in other gears, dealer said I was fine. If it blows up I have a warranty and will piss and moan until I get a new clutch. |
NASA SpecE30 Racer
Sounds like this is your first manual and these issues sound normal to me. Nothing to worry about.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#7 | |
Drives: Raven Manual FRS
Never on Time Always Late
Drives: #silenced crickets
----------------------------------- Press clutch.... wait.... wait..... shift into first... This solves most of those thunk shifts into gear from a stop.. I hated it too until I used this method. ------------------------------------- 2. Shifting from 1st to 2nd gear produces a metallic clunk (not grind). It doesn't sound that bad, more like when cocking a gun, you can hear the gears "meshing" together. Is this normal? Only on 1st to 2nd gear. --------------------------------------- Try shifting slower into 1-2 than any other gear.. The flywheel takes a while to get down to the smooth engagement point in 2nd. --------------------------------------- 3. Are the shift points that low or am I just not getting it? Whenever speeding up (to merge into a freeway from a stop), when I'm upshifting, I get a thud and a jerk. I usually upshifts at 2.5-3K RPM or every 15mph. I let go of the clutch pedal quickly because I don't want to burn out the clutch early. Is this wrong? Should I be letting the clutch go slowly? ----------------------------------------- Shift higher in the RPM's for spirited upshifting..
CO>CA Cartel
Drives: SWP BRZ
sounds normal to me as well. almost all vehicles are different so take your time and learn where clutch engagment is best to smooth out
#10 | |||
#11 | |
What about rev-matching? Does it actually help save the clutch from wearing down? |
#12 | |
A little more info- The clutch is used to engage the engine to the transmission. The synchros are used to engage a selected gear to the drivetrain. Think of the synchros like little clutches for each gear. If you consider the fact that rev matching nearly eliminates wear on the clutch since you can match speeds before engaging it, double clutching can do the same for the synchros. DC'ing won't make any difference in the car's balance, but it's fun, and nice to know if you ever drive a car with a dog box tranny or a munched synchro. |
#13 | |
Drives: WRB BRZ Sport Tech
It's not the clutch your worried about, it's the sudden jump in engine revs when releasing the clutch too fast downshifting with the revs high, or accidentally grabbing the wrong gear. Rev matching also allows the tires to maintain a better grip as the transition from cruising/accelerating to deceleration is smoother. |
#14 |
Drives: Attitude
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Gords_zenith (05-03-2013) |
| shifting from 1st to 2nd | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 05-26-2016 07:15 PM |
| shifting into 2nd | cantaloupe | BRZ First-Gen (2012+) — General Topics | 63 | 06-23-2014 04:47 PM |
| thunk when shifting into first | Skurj | BRZ First-Gen (2012+) — General Topics | 37 | 05-21-2013 04:48 PM |
| MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 03:28 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
