Old 04-29-2013, 04:38 PM   #1
larryt1026
Drives: BRZ Limited
Paint Matched Fender Trim
Hello,
I see a lot of BRZs on the form with the chrome fender trim paint matched. How are you all getting that done. Would like to have it done on my WRB. I tried searching but to no avail. Thanks!
larryt1026 is offline   Reply With Quote
Old 04-29-2013, 05:01 PM   #2
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I think what you what you have is the upgraded chrome trim accessory which is about $80.
Myv is offline   Reply With Quote
Old 04-29-2013, 05:05 PM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Take a heat gun to your chrome fender trim, just enough to work the adhesive underneath it and pull the chrome piece off... It'll be WRB underneath the chrome trim after you remove it.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-29-2013, 05:08 PM   #4
Myv
Myv's Avatar
Damn.. and that thing is $80? I guess the gas cap is the same thing.
Old 04-29-2013, 05:25 PM   #5
ihaskrayon
The Comedian
Yup, the gas cap and chrome fender trim can be removed. OEM paint color will be under each of them
ihaskrayon is offline   Reply With Quote
Old 04-29-2013, 05:48 PM   #6
Ben_G
Drives: Blue BRZ
Just a note....the chrome trim upgrade isn't just an overlay....it's actually a replacement piece for the body colour piece that used to be there....so if you remove the chrome, you'll need to find the body colour piece to replace it....
Ben_G is offline   Reply With Quote
Old 04-29-2013, 07:35 PM   #7
Mitch
form follows function
Drives: RIP '13 BRZ
On my BRZ the area that the chrome covers is part of the rest of fender trim. Are you saying the entire fender trim piece is a different part on the chromed cars?
Mitch is offline   Reply With Quote
Old 04-29-2013, 08:29 PM   #8
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Um I believe the chrome part is just a overlay. Just heat it up a little and pull it off and the factory color is underneath.
Edit: here a previous thread http://www.ft86club.com/forums/showp...15&postcount=6
Area86 is offline   Reply With Quote
Old 04-29-2013, 08:57 PM   #9
Ben_G
Drives: Blue BRZ
oh shit..you're right...for some reason, when I first read the installation instructions on the page here (http://www.ft86club.com/forums/showthread.php?t=6266) i thought it was a replacement piece!!
Subaru BRZ fender trim cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 13 04-23-2013 12:02 PM
JDM Paint Matched Foglight Surrounds OmarGC Cosmetic Modification (Interior/Exterior/Lighting) 0 04-14-2013 07:57 PM
BRZ Fender Trim Wrap xn7485 DIY (Do-It-Yourself) Guides 7 10-11-2012 02:03 PM
Fender Trim, What do you have? joergasm Cosmetic Modification (Interior/Exterior/Lighting) 0 10-10-2012 02:18 AM
