Old 04-29-2013, 06:18 AM   #1
Jeffsu350
Drives: Frs
16" autox wheels
I tried to search but came up empty handed.
Has anyone found a good, light 16x8 wheel that fits well and works well for autox.
I would imagine that on stock power, 16x9 is way too much tire.
Let me know your thoughts and experiences.
Jeffsu350 is offline   Reply With Quote
Old 04-29-2013, 06:37 AM   #2
xwd
What class and what tires are you planning on running?
Old 04-29-2013, 07:29 AM   #3
Jeffsu350
Drives: Frs
I don't autox with SCCA, so my classing is very different
I was thinking 16x8 with a6's would be a lot of fun
Old 04-29-2013, 10:10 AM   #4
xwd
I used to run 16x8 Gram Light 57c wheels with 245/45/16 A6s on my WRX. Unfortunately they stopped making those in a Subaru type fitment (+45 offset) years ago.
The reality is the 245/40/17 A6 weighs less than a 245/45/16, has about the same gearing and shorter sidewall, and 17x8 wheels are plentiful. I wouldn't really run anything narrower than a 245 A6 on a 17x8 wheel for autocross. Those 16x8 Gram Lights were about the same weight as a 17x8 RPF1.
Actually here are some I forgot about, Rota Slipstreams.
http://www.wheeldude.com/catalog/pro...oducts_id=1225
Old 04-29-2013, 11:57 AM   #5
Jeffsu350
Drives: Frs
Dwx- thanks for the info.
I was assuming I could get better gearing, lower weight tires and lower inertia wheels.
For all the reasons you just listed, I'm sure this is why everyone is running 17x8's
Would you go wider than a 245?
Old 04-29-2013, 11:10 PM   #6
EN2_Squirrel
EN2_Squirrel's Avatar
I will be going with a 17x9 RPF1 w/ 35 offset with 255/40/17 for autocross. The fast frs/brz out here use 17x9.
EN2_Squirrel is offline   Reply With Quote
Old 04-30-2013, 01:03 AM   #7
xwd
Do you have coilovers or stock struts. With stock struts you would need a lower offset rim like a +35 or lower to make a 275 fit. I am using the 245/40/17 on a 17x7 for stock class right now.
Old 04-30-2013, 06:47 AM   #8
Jeffsu350
Drives: Frs
Everything is stock right now
My hope was to get wheels/tires that would make me competitive and still allow for growth when upgrading suspension
EN2, what class do you run and do all the "fast" people have coilovers and other suspension bits?
Old 04-30-2013, 06:48 AM   #9
Jeffsu350
Drives: Frs
Old 04-30-2013, 07:59 AM   #10
Biggins
Drives: Yes
Where do you run in DC that doesn't use SCCA rules? NASA?
I'd say just throw good "street" tires on the stock rims and have fun. Wider tires are not necessarily faster with everything stock.
Biggins is offline   Reply With Quote
Old 04-30-2013, 08:04 AM   #11
Jeffsu350
Drives: Frs
I am an organizer with CDC. The classes are based on weight, tire wet rating, and hp.
Old 04-30-2013, 08:16 AM   #12
Biggins
Drives: Yes
Oh okay. I'd still say just put good tires on the stock rims. I met @Areddi at an event who said he does their events. He might know what would be a good setup for their rules. I stick to SCCA rules since they're the standard.
Old 04-30-2013, 02:58 PM   #13
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
Yep they do a modifier based on Weight, HP and street or not tires. I would recommend sticking with a 17" like the stock wheels. From my experience, there are more tires available in the 17 size to find what you want at the right price. I am running 225/45's on the stock wheels and they're great.
I don't think anything wider than a x8 is necessary for this car cause you can get up to a 255 on that, and there just isn't enough horsepower for it to matter bigger than that.
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 05-02-2013, 08:52 AM   #14
EN2_Squirrel
Yes. I have coilovers, and a few others have springs/ coilovers/other suspension mods. I learned, the hard way, that getting a dedicated set of wheels and tires is the best car upgrade. Wider wheels and tires will move you out of stock class, with the scca, the best way to get faster is seat time and if at all possible talk to/ ride with the guys who have been doing this for years
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
Rays Volk-Racing TE37SL 18" & Yokohama Advan RS-II 18" wheels eauto Wheels and Tires 3 01-10-2013 05:50 AM
TSW Wheels 17" 18" Nurburing + Interlagos and More (Wheel+Tire Package Available) MIKE@MRTIRESOLUTIONS Wheels and Tires 0 12-20-2012 05:12 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 09:26 PM
