Old 01-30-2012, 12:59 PM   #1
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
Autobuild.de reviews the GT86
Translated from German
Strong Celica successor
The new Toyota 86 GT offers driving fun, emotion and adrenalin - for less than 30,000 €. First ride with the Japanese artist drift and successor of the legendary Celica!
By Georg Kacher on the former Grand Prix circuit on the outskirts of Madrid, Jarama, the new Toyota GT 86 show what he draufhat - and whether he actually in the footsteps of MR2 , Celica and Supra runs. Against a Porsche Cayman does the Toyota on a timed lap, but not random, but the GT 86 has an even lower center of gravity, a more aggressive axle load distribution, a more direct steering and a higher rotating piston engine. The ****pit is sporty, but not spartan. The driving position seems likeable old school: the steering wheel without multi-function, classical floor brake, large round instruments, great seats, right next to the gearshift buttons for traction control and stability program. Only the start-stop button and the standard navigation system may provide a cross reference to the production in 2012.
The two-liter flat-six of the Toyota GT 86 sounds bad, throaty and metallic than the good of the Japanese inline four cylinder. He stands at 200 hp while the food properly, but when Subaru is already the next stage with a supercharger and 300 hp. Specifically for the GT 86 is a lightweight and compact front-mid engine was designed, its high compression ratio of 12.5:1 only by the Toyota D4-S direct injection was possible. The maximum torque of 205 Nm is available across the cloud boundary at 6600 tours available, but it is 90 percent of the shear force distributed over an unusually wide plateau, which reaches 2200-6200 rpm.
The GT 86 particularly fascinated by his ride. This car has two steering wheels: one is circular, the other is operated with the right foot. Of hire because, Lupfer, and with a lot of gas across the curve. Toyota extends snappy turn-in and a gentle step on the pedal to the rear vorbeizutreiben with grandeur at the apex. The only condition: The flow of torque must not separate. The 1200 pound lightweight coupe sprints in 7.2 seconds from 0 to 100 km / h and is 230 km / h fast. The Mixverbrauch is 6.0 liters, the base price should be less than 30,000 euros. . You might want to take the manual switch is an equally aggressive staggered six-speed automatic transmission order, which is operated via paddles on the unusually small steering wheel (diameter of only 365 mm)
More information about the new Toyota GT 86 is available in AUTO BILD 5 / 2012 - from Friday , 3 Trade in February 2012.
http://www.autobild.de/artikel/toyot...t-2841271.html
poormans_LFA is offline   Reply With Quote
Old 01-30-2012, 01:02 PM   #2
#87
I usually post drunk
#87's Avatar
2 liter flat six, not sure if want
#87 is offline   Reply With Quote
Old 01-30-2012, 01:02 PM   #3
DommerEOD
I'm a Carcissist
DommerEOD's Avatar
Drives: JERRV , 11 STI, 07 FJ
thanks for the post!
I am Ron Burgandy?
DommerEOD is offline   Reply With Quote
Old 01-30-2012, 03:52 PM   #4
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
From the source article: "Der Zweiliter-Boxer des Toyota GT 86 klingt böser, kehliger und metallischer als die braven Reihenvierzylinder der Japaner."
It translates to:
"The Toyota GT 86's two liter boxer sounds meaner, throatier and more metallic then other strong Japanese inline four cylinders."
It doesn't say flat six, don't know why the OP's translation has it, unless they made a goof and edited the original doc after the translation was done.
Re_Invention is offline   Reply With Quote
Old 01-30-2012, 03:58 PM   #5
frusciantrix
Drives: Mini R56 JCW
I like the hint that Subaru is working on a supercharged version
frusciantrix is offline   Reply With Quote
Old 01-30-2012, 04:04 PM   #6
Kunzite
Drives: Toyota Auris
That's a google translate "feature"
0-100 in 7.2 and 6l/100km? One sounds slow-ish, the other to good to be true.
Thanks for posting!
Kunzite is offline   Reply With Quote
Old 01-30-2012, 04:06 PM   #7
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
7.2 secs 0 to 62 MPH? Dang..it's getting slower...but hey these are still prototypes. Nobody has done a proper 0 to 60 or 1/4 time.
tripjammer is offline   Reply With Quote
Old 01-31-2012, 03:51 AM   #8
frusciantrix
Thanks for posting!
Europe fuel consumption methods are out-dated.
Old 01-31-2012, 04:09 AM   #9
serialk11r
Drives: '06 AM V8V Coupe
I wouldn't say that...IMO the only relevant figures when it comes to fuel consumption are drivetrain type (hybrid or not), weight, and constant speed highway cruise fuel consumption in top gear. I guess EPA city test would be fine.
Old 01-31-2012, 04:33 AM   #10
Dark
Elite Padawan
Dark's Avatar
It's all speculation. If it's true, I hope it comes out next year.
Dark
Dark is offline   Reply With Quote
Old 01-31-2012, 06:57 AM   #11
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I got a headache reading this.
SUB-FT86 is offline   Reply With Quote
Old 01-31-2012, 07:00 AM   #12
SUB-FT86
86 Member
I wonder if it's because the FR-S isn't making much power above 6500? I read a review that said the last 1k rpms is powerless so I guess that could affect the 0-60 time.
Old 01-31-2012, 08:03 AM   #13
Matador
hashiryu
Drives: Mk4 Supra
Can one of our German members hook up translation?
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 01-31-2012, 08:49 AM   #14
frusciantrix
A fast translation of the important parts:
"Gegen einen Porsche Cayman macht der Toyota auf einer gezeiteten Runde zwar keinen Stich, aber der GT 86 hat einen noch niedrigeren Schwerpunkt, eine noch aggressivere Achslastverteilung, eine noch direktere Lenkung und einen noch höher drehenden Boxermotor. Das ****pit ist sportlich, aber nicht spartanisch. Der Fahrerplatz wirkt sympatisch old school:"
The GT86 has against a Porsche Cayman no chance on a timed lap but the Toyota has a more aggressive weight distribution, a lower centre of gravity, a crispier steering and the higher revving engine. The coc*kpit is sporty but not empty - just old school.
"Das maximale Drehmoment von 205 Nm steht jenseits der Wolkengrenze bei 6600 Touren zur Verfügung, aber dafür verteilen sich 90 Prozent der Schubkraft über ein ungewöhnlich breites Plateau, das von 2200 bis 6200 Umdrehungen reicht."
The maximum torque of 205nm (151ft-lb) is available at 6.600 rpm but 90% of the torque is available between 2.200rpm and 6.200rpm which is unusual (means it's positive for a natural aspirated car).
"Der GT 86 fasziniert vor allem durch seine Fahreigenschaften. Dieses Auto hat zwei Lenkräder: eines ist kreisrund, das andere wird mit dem rechten Fuß bedient. Von wegen anstellen, lupfen, und mit viel Gas quer um die Kurve. Im Toyota reicht zackiges Einlenken und ein sanfter Tritt aufs Pedal, um das Heck mit Grandezza am Scheitelpunkt vorbeizutreiben. Einzige Bedingung: Der Drehmomentfluss darf nicht abreißen"
The GT86 fascinates with it's driving characteristics. The car has two steering wheels (not literally speaking). The one controls the front wheels the other controls the back with your throttle inputs. There is no need for bringing the car out of balance to make it drift. Just bang the throttle and the heck of the car comes alive. But only if you maintain high revs.
Video: Ken Gushi Drifts and Reviews the Scion FR-S ! TeckniX FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 97 03-25-2014 10:29 AM
BRZ Test Drive Reviews Compilation List Hachiroku BRZ First-Gen (2012+) — General Topics 69 12-23-2012 10:24 PM
FR-S and 86 GT86 Test Drive Reviews Compilation List Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 118 06-26-2012 02:28 PM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 10:41 PM
