Old 01-26-2012, 02:01 AM   #1
LexusFman
LexusFman's Avatar
Drives: None
Can hellaflush be done "right"
Can you make a car look flush or hellaflush while retaining driveability and preformance? I know some idiots in the Hellaflush scene do stupid shit like cut springs and put rediculous ammounts of camber they can't control on their cars but I don't see why, if a combination of good quality parts and planning, one couldn't make a Hellaflush car be just as safe as stock if not more (minus stretched tires, they don't belong anywhere other than car shows). I'm asking because I really like the hellaflush look but I don't want to compromise saftey to do it. If I hit some little kid just cause my car was hellagay, id feel bad and saftey is starting to factor more in my vehicle selection.
LexusFman is offline   Reply With Quote
Old 01-26-2012, 02:08 AM   #2
Giccin
Giccin's Avatar
With my speeding habits. I personally don't think hellaflush can ever be done right. :P
Scrappppppeeeeeee.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 01-26-2012, 02:11 AM   #3
#87
I usually post drunk
#87's Avatar
I thought hellaflush meant cambered wheels that extend past the wheel well with stretched tires? They basically try to fit the widest wheel possible and set the car at the lowest height while still being able to "drive", no?
But anyway you sound stupid based on the bolded part above so just slam it and rub and scrape all day err day, if you don't crack an oil pan you are doing it wrong.
#87 is offline   Reply With Quote
Old 01-26-2012, 02:23 AM   #4
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Yes, but by the time you fix all the idiotic crap involved in Hellaflush, it's not really Hellatrendy anymore. There's the obvious stuff like the excessive camber and stretched tires. But if you actually want your mods to improve handling you're going to have issues with the 2"+ drop in height. It's going to play holy hell with your suspension geometry, there's a good thread covering this in the Suspension forum. You'd need either drop spindles or extended ball joints to mitigate some of that. But the most important thing is to make sure you've still got adequate suspension travel, I can't stress that enough. And also, you'd want to stay away from huge wheels with rubberband tires: Keep it above ~40 series.
But at that point, you've got a well modded car with aggressive wheel fitment, which isn't particularly "Hellaflush".
Originally Posted by #87 View Post
you sound stupid ... if you don't crack an oil pan you are doing it wrong.
Oh, the irony.
old greg is offline   Reply With Quote
Old 01-26-2012, 12:53 PM   #5
LexusFman
LexusFman's Avatar
Drives: None
Originally Posted by LSxJunkie View Post
You can run low offset wheels to push your tires out farther and trim your fender/quarter lips so they don't rub. You can run drop spindles so you can get low without compromising suspension geometry. You can align your car so that you're actually maximizing contact patch. You can run appropriate sized rubber.
Congratulations, you now have a car that looks appropriate. Flushtards will hate it.
(This car has the same tire sizes as a stock ZR1)
That's flush enough for me! That's basically hellaflush without the neon colored wheels and bike rack(wtf? If you have a bike it makes sense but still). I think a lot of people confuse hellaflush with demon camber. Any cambered car can't be considered truly hellaflush since camber, toe, and caster aren't flush. And I still don't understand people streeting stretched tires. It dosent take much to know stretched tires aren't streetable.
Old 01-26-2012, 01:10 PM   #6
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
yes...lets not mistake Oni Cars as the same as the Stance Movement
Oni Car
WingsofWar is offline   Reply With Quote
Old 01-26-2012, 01:30 PM   #7
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Old 01-26-2012, 01:49 PM   #8
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Hellaflush is like those Oni Cars, what LSx posted is NOT Hellaflush, it's Well Fitted Wheels. Let's not confuse the two...
- The Ancient BRZ Sacrament
by Zaku
Old 01-26-2012, 02:10 PM   #9
mastawyrm
Drives: '10 Mini ClubmanS '95 Z28 08 VW GLI
Seems to me the definition of hella flush is to have broken/screwed up suspension with a tire/wheel combo thats just plain incorrect. So no I don't believe there is a right way to have a broken car.
mastawyrm is offline   Reply With Quote
Old 01-26-2012, 02:13 PM   #10
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
fittment.......such a loose term now days.....
Old 01-26-2012, 02:15 PM   #11
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Can hellaflush be done "right" is an oxymoron. A properly done suspension wheel/suspension combo is properly done and not hellaflush.
tranzformer is offline   Reply With Quote
Old 01-26-2012, 02:16 PM   #12
Dragonitti
Well fitted wheels > Hella(can't drive properly)flush.
Old 01-26-2012, 02:22 PM   #13
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
If i'm not mistaken that S2k is bagged which is a waste imo.
Another thing about this hellaflush is that it's cool to have messed up body work due to your setup? So in turn having a crappy looking car is cool?
I'd rock a flush VIP car though. Let's also address what the hell "stance" is because that crap confuses me also as to what it is.
I love the Z and vette above though, proper fitment that looks performance oriented.
Ryuu0u is offline   Reply With Quote
Old 01-26-2012, 02:26 PM   #14
#87
#87's Avatar
The term stance to me is not associated with the hellaflush movement. IMO it is subjective and refers to the overall look of the car. For example I would say the BRZ STI has a very good, but not perfect, stance and the stock BRZ is a meh stance.
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
