Old 04-18-2013, 10:10 PM   #1
Mo707
Mo707's Avatar
Off topic honda problems. Help?
So i don't know where too post this but about a month ago i bought a 1998 Honda civic with 244,*** miles on it for $600. When I got the car it wasn't running right. A few weeks in my shop class and i get the car running "properly". I put an aftermarket exhaust on it and about two days ago my friend(who was driving behind me) tells me he saw smoke coming out of my exhaust when i really gas it. I've also noticed that the car is having a lot of trouble accelerating. I check my oil about 10 minutes ago and I'm on the no oil line. Im thinking the head gasket is blown but my friend is thinking the piston rings. Any idea's/suggestions?
***Notes***
Its a D16y5
Just did an oil change
Size:  223.5 KBaName:  ImageUploadedByTapatalk1366337371.583667.jpg
Mo707 is offline   Reply With Quote
Old 04-18-2013, 11:09 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what colour is the smoke?
if it's blue, you've got oil problems (rings)
if it's white, you've got coolant problems (head gasket)
if it's black, you've got combustion problems (spark, fuel, timing, etc)
if you can't tell, then probably all 3
Old 04-18-2013, 11:12 PM   #3
Mo707
Mo707's Avatar
Its like a gray smoke and if I'm hauling a** its a lot of smoke.
Old 04-18-2013, 11:26 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
have you checked your sparkplugs?
you can google a chart to help you diagnose what's going on by how the sparkplugs look like
when was the last time the plugs were changed?
Old 04-18-2013, 11:28 PM   #5
Mo707
Mo707's Avatar
The spark plugs were the first thing i changed when i got the car. They should be new. Only a month old but ill check again.
Old 04-18-2013, 11:29 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
use this when you check them
make sure to check all 4
Old 04-18-2013, 11:31 PM   #7
Mo707
Mo707's Avatar
Thank you!!! Ill check them tomorrow!
Old 04-19-2013, 12:13 AM   #8
UltraFRS
UltraFRS's Avatar
Do a compression check and that should give a good idea on the rings and head gasket. With that many miles the smoke could be leaky valve seals as well.
UltraFRS is offline   Reply With Quote
Old 04-19-2013, 12:50 AM   #9
Mo707
Mo707's Avatar
I checked the valves when i got the car they were good. Just didnt look at the seals. How do i do a compression check?
Old 04-19-2013, 06:44 AM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
All that dark grey smoke would normally indicate incomplete combustion. If you're spark plugs are new, check the fuel pressure and clean the injectors.
A compression test is done by removing all of the spark plugs, screwing a compression tester into each of the spark plug holes in turn, cranking the engine and getting a reading on the gauge. You should be able to look up what the reading should be for your engine.
A leaking valve seal will not show up on a compression test. You'd have to remove the valve cover and inspect them.
A compression test is a good pass/fail type of test, but for comprehensive results you'll want to do a leakdown test. It's very similar, but you need a leakdown tester and you don't crank, just set the pistons to TDC on the compression stroke. The tester flows air into the cylinder and measures how much is leaking. And you can then find where it's leaking. Bubbles in the coolant, you have a dead head gasket. Excessive air coming from the dip stick tube, your rings are gone or you have a dead head gasket. Air heard coming from the throttle body and the intake valves aren't sealing. Same for the exhaust.
Considering this is a Honda, you might want to do some reading over at Honda-Tech.
Old 04-19-2013, 09:41 AM   #11
Mo707
Mo707's Avatar
I just put in new fuel injectors when i did the spark plugs. I dont get it. Everything should be good. Where can I find a compression tester?
Old 04-19-2013, 10:12 AM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what about o2 sensors
do you have any Air/Fuel ratio diagnostic tools?
Old 04-19-2013, 10:14 AM   #13
Mo707
Mo707's Avatar
No. I do most of my work in my auto class because i dont have much tools at my house but we dont have a diagnostic tool. Do they rent them out at auto zone?
Old 04-19-2013, 01:49 PM   #14
Calum
That Guy
Autozone lists them on their website. They're pretty common to be found in most tool stores, take a look.
http://www.autozone.com/autozone/cat...35&isApp=false
The be all end all Traction Control topic empower-auto Issues | Warranty | Recalls / TSB 14 09-19-2017 03:41 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
Is there a Topic Comparison for the FRS, BRZ, and BRZ Limited? SSSJDanny Site Announcements / Questions / Issues 1 06-20-2012 07:49 PM
