Ontario's FT86
Drives: 2016 Lexus GS-F
Bigger front pipe to smaller diameter cat-back, bad idea?
Hi,
I am currently running 2.5 inch un-resonated perrin cbe. I was wondering if I can pair it up with 2.75 inch over pipe and front pipe. Would this work? Are there any disadvantage? Thanks!
Ontario's FT86
anyone?
Chronic Flashturbator
Drives: '13 Scion FR-S MT
The only disadvantage is that you'll be slightly more constricted on the cb. I believe that with NA, the main restriction is the mufflers themselves, not necessarily the pipe diameter; I don't think you'll see any difference at all unless you're going straight pipes with a turbo, but I'm no pro.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
That Guy
Drives: 2013 asphalt FRS MT
As the exhaust cools on its way through the exhaust it's volume decreases. I've often wondered why exhausts aren't designed to maintain a velocity, meaning a gradual decrease in tubing size, as opposed to maintaining just the tubing size. You MIGHT even be doing something good.
#5 | |
Ontario's FT86
#6 | |
Custom User Title
Drives: Asphalt FR-S MT
Drives: Sterling BRZ Ltd
^^^ Agreed, you could step it or reduce it down but thats not all that gradual. A pipe that slightly tapers in diameter while following the windy path under the car sounds like a night mare to produce.
Good thinking though
That Guy
Its not like your going to hurt anything. Ive been running a 2.5" over pipe and catless front section with the stock cat back for a few weeks. Nice and quiet
#10 |
Custom User Title
There is one option that may actually be cheaper to produce, but it would be a bit heavier. Stamped halves (top and bottom) would do the job. The initial costs would be much higher though as you would need molds to stamp with.
#11 |
Custom User Title
Examples:
The exhaust headers as will as the front pipe have stamped covers I believe.
#12 |
Drives: frs
you just will get more pick up but your back pressure and top end will be reduced. No big deal. If you were turbo then that would be close to fatal. The size difference isnt that much so not going notice it easily.
| TRD Exhaust Pipe Diameter | Jacob G. | Engine, Exhaust, Transmission | 24 | 04-10-2018 08:18 PM |
| Front Spring Diameter | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 12-17-2012 12:06 PM |
| Exhaust Pipe Diameter | fmsida | Engine, Exhaust, Transmission | 9 | 09-27-2012 04:46 PM |
| going significantly smaller idea | Nepenthe | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-08-2012 08:48 AM |
