Old 04-11-2013, 08:14 PM   #1
ShowTime_DW
Drives: FRS
Smile Got new whiteout MT FRS and need some help
Got my new FRS 2days ago and it is beautiful!!! But, have some issues to drive when start in 1st gear and change to second gear. Is anyone can tell me when to change gear from 1st to 2? I used to drove MT corolla....
Aslo hear some clinking sound when change gears and release the clutch , is it normal? I also feel the clutch pedal is super high for me ....
ShowTime_DW is offline   Reply With Quote
Old 04-11-2013, 08:34 PM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
It's normal for the clunking sounds. The car needs to be warmed up in order for the 1st to 2nd gear and going back to neutral to be smooth.
Bach415 is offline   Reply With Quote
Old 04-11-2013, 08:41 PM   #3
ShowTime_DW
Drives: FRS
Thanks for replying. I heard a lot complaining about this sound, but seems like it is normal.
I can not drive smooth from 1st gear to 2nd . When should I change the gear?
Old 04-11-2013, 08:45 PM   #4
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
possibly around 2-2.500rpms... Thats if your just cruising along.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 04-11-2013, 08:47 PM   #5
Bach415
Bach415's Avatar
I would say 2.5-3k rpm instead of what usptwins said. Just switch the gears slowly. When the car is warmed up(or driven for ~5-10 minutes), it should be much more easier to switch gears.
Old 04-11-2013, 08:53 PM   #6
ShowTime_DW
Drives: FRS
Did you adjust the Clutch Pedal hight? lol
Old 04-11-2013, 09:00 PM   #7
W2
W2's Avatar
Drives: Firestorm FR-S
It was hit on above but yes shifting gets better once the car gets warmed up. There are a lot of threads discussing this and it is completely normal.
I did find the shifting got better after a few thousand miles but the best thing I did was change out the transmission fluid. I personally went with Amsoil but other members here have been having great luck with different premium brands as well.
W2 is offline   Reply With Quote
Old 04-11-2013, 09:27 PM   #8
ShowTime_DW
Drives: FRS
Did you change the transmission oil by yourself ?
Old 04-11-2013, 10:19 PM   #9
Bach415
Bach415's Avatar
Nope. Stock clutch pedal height. I decided to just keep it the way it is and do muscle memory on where the engagement point is.
Old 04-11-2013, 10:46 PM   #10
W2
W2's Avatar
Yes, it was very easy and there is a good DIY write up in the DIY section. There is a drain plug and a fill plug, the only really special tool you need is a pump to get the new oil in as space is limited around the fill plug. If you do go this route you might as well do the diff at the same time, equally as easy.
Old 04-11-2013, 10:56 PM   #11
ShowTime_DW
Drives: FRS
Do you know if I adjust the clutch height to lower position, is that mean the free distance will be decreased?
Old 04-11-2013, 11:06 PM   #12
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
There is a setting you can enable that will tell you what gear you are in and when to shift. It is disabled by default. Look it up in your owners manual.
I'm at 1,500 miles and I am just starting to get used to this clutch...it's weird.
Mad_Mike is offline   Reply With Quote
Old 04-11-2013, 11:07 PM   #13
Bach415
Bach415's Avatar
I have no idea. Just look in the DIY section for the clutch adjustment thread. I'm sure there are more answers relating to adjustment of the clutch pedal there.
Old 04-12-2013, 02:24 AM   #14
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Yes. The white ones because racecar.
Actual, take it slow for break in. You'll get used to the actuation eventually.
First gear is quite low. It's going to sound like you're trying to race the next lane every time.
Take the time to make the shift to second leisurely.
I'm getting used to matching revs to the speed I'm moving on the 1 to 2 shift and easing the clutch.
It's been a month and a half though. Only getting used to it now, as I've been driving all day every day for almost a week.
On my motorcycles, I've found that it's easier to make a clean shift 1 to 2 in the upper revs.
The FR-S seems to work similarly. It's not really practical in light to light driving at 25 max.
Yet Another Whiteout FR-S ProTekk Member's Car Journals 14 01-31-2013 11:52 AM
Whiteout FRS Mrqb22 Member's Car Journals 5 09-25-2012 03:49 PM
One more Whiteout raleav FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 07-08-2012 10:19 PM
My new Whiteout FR-S! Flawless22 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-05-2012 02:46 AM
My whiteout fr-s F3dzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-04-2012 07:25 AM
