Old 04-05-2013, 07:49 PM   #1
radroach
Drives: car
Do I have the ECU, low idle problem?
OK so I've been in denial with myself that I have an ECU issue with low idle/ rough idle etc. so I'll describe the following issues and maybe you guys can help me determine whether I should take it to the dealership:
-Car starts fine with good exhaust note
-After 30 seconds to 1 min. the rpm's drop to 550-600 rpm's seen in this photo (link), engine noise changes tone to a quiet, bubbly sound.
-With the idle this low, it can be very easy to stall the car and too hard to get a quick, smooth start. The change in feel when the idle drops I feel like the car is going to stall and I lose confidence when I feel the engine lose power. I sometimes blip the throttle to 1k rpm to make sure I don't have a bad start.
Is this the same low idle issue that other people have reported?
Old 04-05-2013, 08:37 PM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
There is an idle dip issue where the engine would idle at 600 RPM but once in a while it drops to 500 RPM and jumps up to 800 RPM.
I've never heard on low idle issue.
What you described is a normal operation.
When the engine is started cold, it idles at higher than 1000 RPM.
The idling RPM would slowly go down to 600 RPM as the engine warms up.
Sigh-on-Rice is offline   Reply With Quote
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
radroach (04-05-2013)
Old 04-05-2013, 08:43 PM   #3
radroach
Drives: car
Alright thanks. I've fixed my low idle issue, just rev the shit out of the engine at stoplights and make people balk and laugh.
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle fluctuates? Fontz_86 Issues | Warranty | Recalls / TSB 3 04-01-2013 02:13 AM
Response from Scion about rough idle problem ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 10 10-09-2012 10:41 PM
Idle Fluctuation FIX empower-auto Issues | Warranty | Recalls / TSB 2 09-14-2012 02:36 PM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
