Old 04-02-2013, 05:50 PM   #1
zooplane
Drives: SSM BRZ
Keep fresh air scoop?
I've done the Zeta performance intake tube with a works Motorsport DIF. however, I got rid of my fresh air scoop. Should I keep it on?
zooplane is offline   Reply With Quote
Old 04-02-2013, 06:00 PM   #2
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
The stock tube that puts the intake in front of the radiator?
From what I've seen on here everyone says it keeps the intake temps down.
EvilBeaverFace is offline   Reply With Quote
Old 04-02-2013, 06:21 PM   #3
zooplane
Drives: SSM BRZ
Yeah that one. Really? I took it out and noticed a difference in sound and response. Others?
Old 04-02-2013, 06:32 PM   #4
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I took off my scoop, because it require when I installed the aFe Takeda Intake. Certainly at the low end, the car feel more power at the 1st and 2nd gear.
Old 04-03-2013, 04:07 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Put it back in! I'll reference you back to my thread here with some actual datalogging on temps and MAF. You'll get the improvement in response by doing the filter alone anyway, by removing the snorkel all you've done is open up the airbox to heatsoak.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-03-2013, 04:09 AM   #6
EvilBeaverFace
Like I said... this ^^
Old 04-05-2013, 11:40 PM   #7
zooplane
Drives: SSM BRZ
Injen short ram or perrin CAI with Perrin tube?
Old 04-06-2013, 01:15 AM   #8
wootwoot
Drives: FRS
neither.... injen is awful in every way. Perrin is overpriced for what it is IMO. You would get the same performance out of an inlet and drop in filter for much less money.
wootwoot is offline   Reply With Quote
Old 04-06-2013, 12:45 PM   #9
Scoobyrs25
Drives: 01 RS, STI V6 RA Limited, BRZ
You can have the best of both worlds actually. I removed mine and added a bent piece of aluminum that allowed cold air in and kept the hot radiator air out. Amazing response and now more power throughout the rev band.
Scoobyrs25 is offline   Reply With Quote
Old 04-06-2013, 06:52 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
Any pics of this?
1974 TA22 Celica
2013 86 GT
Old 04-06-2013, 07:00 PM   #11
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
The tip of the snorkel (labeled "Fresh Air Scoop" below) resembles a Venturi tube with an entry cone of 30 degrees and exit cone of 5 degrees. Theoretically, this ensures constant air pressure into the airbox for predictable (rather than sporadic) readings to the MAFS. Again, that's theory so take it as you will FWIW. I wonder if people who remove their snorkels know they are losing this Venturi functionality. I sure as hell didn't know when I removed my snorkel til I looked it up.
Velocity stacks in race engines also utilize Venturi openings.
Old 04-06-2013, 09:50 PM   #12
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
What? Why..? I have then Injen and it is definitely not awful in every way.... Got statistics to prove its worthlessness?
LeeMaster is offline   Reply With Quote
Old 04-06-2013, 10:15 PM   #13
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by switchlanez View Post
...venturi..
ding ding
winner
Please stop, youre making way too much sense here.
Huehuecoyotl is offline   Reply With Quote
Old 04-07-2013, 01:48 AM   #14
wootwoot
Drives: FRS
Statistics? Lol... no.... no statistics.
It takes hot air from the engine bay. That is a bad thing. I believe it also produces the leanest AFR of all intakes tested to date. Also a bad thing. Search. Lots of info on this topic already exists. I thought it was common knowledge by now...
Front bumper air scoop? Tim_Asphalt_FRS Engine, Exhaust, Transmission 40 02-24-2013 12:20 PM
Hood Scoop? joergasm Cosmetic Modification (Interior/Exterior/Lighting) 16 10-30-2012 04:53 PM
SCOOP: Subaru didn't want D4S (and neither do I) coyote Engine, Exhaust, Transmission 89 03-20-2012 10:20 AM
SCOOP: Toyota changes mind, 86 is cancelled coyote Scion FR-S / Toyota 86 GT86 General Forum 9 12-14-2011 12:06 AM
FT-86 Scoop by 7tune. Car coming in Nov. 2011 7tune-Adam Scion FR-S / Toyota 86 GT86 General Forum 122 08-14-2010 01:15 AM
