Old 11-01-2012, 10:06 PM   #1
EN2_Squirrel
EN2_Squirrel's Avatar
Question Rear control arms
agency power, gt spec, cusco, dme. which one to get. i am hoping for ease of adjustability. I have coilovers on and have 2 degrees of neg camber.
EN2_Squirrel is offline   Reply With Quote
Old 11-01-2012, 10:29 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Ease of adjustability go with SPC but if you have 2 degrees on the left and right leave it alone it's fine, if it was bad uneven i would say to change it but you should be ok.
JoeBoxer is offline   Reply With Quote
Old 11-01-2012, 10:43 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
Turn in Concepts has the SPCs and likes them, you can't go wrong with Cusco, the upcoming whitelines look pretty good, and agency power mostly just copies stuff.
And really, how important is "ease of adjustability?" They all work pretty much the same way and it's not going to get done very often.
jamal is offline   Reply With Quote
Old 11-01-2012, 10:45 PM   #4
EN2_Squirrel
well i light track duty so being adjustable in the parking lot at an autox event is pretty much a must
Old 11-01-2012, 10:47 PM   #5
JoeBoxer
JoeBoxer's Avatar
How are you going to adjust alignment in the parking lot? You should be able to get a good enough alignment for daily and autox that shouldn't need adjusting.
Old 11-01-2012, 10:50 PM   #6
jamal
jamal's Avatar
Drives: Legacy GT
Are you bringing alignment gear to every auto-x? Chances are you will just make things worse. Adjusting the camber changes the toe too.
Old 11-01-2012, 11:17 PM   #7
EN2_Squirrel
it is a balance with tire wear, tread life. the 2 deg of neg camber is not helping for dd. also i used, terribly, the adjustzability in a parking lot as a ease of adjustability example. and i have done alot of suspension work so i know the ups and downs. I am appreciative and thankful for your knowledge. If i dont make sense i blame the excess beer in me now.
Old 11-01-2012, 11:35 PM   #8
gmookher
must be the beer: You done allotta suspension work so you already know this:
you cant "parking lot change the rear camber" without affecting the rear toe...unless you will have a camber gauge AND a toe protractor, or youre gonna be screwing up thrust line...I dont suggest this on this car, I agree there are some cars you and dial in 'at the track' I suspect this isnt one of them
gmookher is offline   Reply With Quote
Old 11-02-2012, 12:51 AM   #9
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
You don't need alignment gear for a parking lot change. All you need to do is mark the changes when the car is on an alignment rack with a paint pen. 1 color for street settings, and the other for track...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 11-02-2012, 01:08 AM   #10
OrbitalEllipses
Drives: Attitude
One more mention for billet Whiteline arms.
Old 11-02-2012, 02:03 AM   #11
gmookher
good point, stand corrected
I just set it for the track, and forget it..
Old 11-02-2012, 04:39 AM   #12
OrbitalEllipses
Drives: Attitude
This would be a good time to link a parking lot alignment thread, complete with string.
Old 11-02-2012, 08:53 AM   #13
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
This x100
The cusco and Whiteline (as it appears) are hard to adjust without dropping the arm at the crossmember point. The subframe covers part of the turn buckle and its hard to get a crescent wrench in there.
The AP is much easily adjustable.
F1point4 is offline   Reply With Quote
Old 11-02-2012, 02:05 PM   #14
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Originally Posted by F1point4 View Post
This x100
That's very true. It's such a bit*h to adjust them.
I would say to get the one which can be easier to adjust so the alignment shop will not charge you extra to do it.
AJ PwR is offline   Reply With Quote
Rear lower control arm part # BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-15-2013 12:33 AM
Enjuku Racing - NRG/DME Rear Lower and Toe Arms ** New Product ** Enjuku Racing Brakes, Suspension, Chassis 0 10-17-2012 11:55 AM
Delete driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-31-2012 08:42 PM
Agency Power Control Arms | Best Price Anywhere IslandImportPerformance Brakes, Suspension, Chassis 0 07-20-2012 02:17 PM
