Old 04-01-2013, 01:10 AM   #1
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
More Low, Less Camber
Do adjustable lower control arms help with this? With all these cars I see being lowered, I see -3* of camber and it looks like the rear wheels are broken or bent. I'm not a huge fan of the cambered tire look.
If you install adjustable rear control arms can you lower the car and adjust the camber to as close to 0* as possible so the wheel is actually straight and flush with the car?
If not anyway to enlighten me on the subject would be greatly appreciated.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 04-01-2013, 02:58 AM   #2
delusional
B R Z
delusional's Avatar
Drives: BRZ 6MT Limited
well to lower your car you will need either springs or coilovers. lower control arm will help adjust the camber after you lower it. lower control arms are for the rear only. for the fronts, you will need either camber bolts or camber plates. and you do not want 0* camber. you will want some negative camber. i think it around ~-1.5* camber should be good.
delusional is offline   Reply With Quote
Old 04-01-2013, 03:06 AM   #3
robispec
Drives: Black frs project
http://www.ft86club.com/forums/showt...highlight=robi
our fronts do a lot my car is lowered 3" from stock I'm using whiteline rear upper control arm suspension bushings for camber correction and am very happy with them.
Robi
robispec is offline   Reply With Quote
Old 04-01-2013, 12:37 PM   #4
nemesisdrift
Drives: 2013 LR Limited
my car is tucking tire and the rear camber is almost zero. then again i drift it.
nemesisdrift is offline   Reply With Quote
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
Camber sw20kosh Tracking / Autocross / HPDE / Drifting 0 02-19-2013 02:43 PM
camber kit? iHeartmyFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-15-2013 07:30 PM
