Old 01-14-2013, 06:44 AM   #1
iHeartmyFR-S
iHeartmyFR-S's Avatar
Drives: 2013 Scion FR-S (Raven Black :)
camber kit?
I am looking into getting a set of Coilovers for my FRS
I also want to get Camber Kit when i lower my car so I dont have to deal with bad camber wear on my tires all the time.
I been searching around and cant seem to come across any Camber Kits...
Has anyone on here gotten Camber Kits for their FRS/BRZ yet??
or if anyone knows where I can perhaps get a Kit for it?? if they even make a kit??
thanks
2013 FR-S Raven Black (CURRENT)
2002 BMW 325Ci e46
1991 EF Sedan
1991 CRX Si Built B16 Fully Caged All SiR Interior and Exterior
1993 DA JDM GSR w/ all type r internals/B16 tranny 2way clutch type LSD
iHeartmyFR-S is offline   Reply With Quote
Old 02-14-2013, 03:15 PM   #2
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
There are actually a ton of camber adjustment kits out now so you shouldn't have a problem adjusting the camber on your new coilovers! We have had good luck with the SPC stuff so we usually recommend them.
Circuit Motorsports is offline   Reply With Quote
Old 02-14-2013, 03:19 PM   #3
sw20kosh
Drives: 2013 Black FR-S
What about for stock setup in the front? Crash bolts and the Com-C Top Mounts which are on hold from the manufacturer? Anything else?
Old 02-14-2013, 04:06 PM   #4
UltraFRS
UltraFRS's Avatar
Why not use camber bolts? As Circuit Motorsports said SPC is a good brand and is the same as Whiteline and can usually be found at any auto parts store...think its part #81280 and would be better than the crash bolts.
UltraFRS is offline   Reply With Quote
Old 02-14-2013, 04:36 PM   #5
sw20kosh
I have the whiteline camber bolts.
Old 02-14-2013, 11:22 PM   #6
maxx1957
maxx1957's Avatar
Drives: red
What would you guys suggest for the rear?
maxx1957 is offline   Reply With Quote
Old 02-14-2013, 11:50 PM   #7
donutfilling
donutfilling's Avatar
Drives: frs
adjustable lower control arms
donutfilling is offline   Reply With Quote
The Following User Says Thank You to donutfilling For This Useful Post:
whataboutbob (02-14-2013)
Old 02-14-2013, 11:52 PM   #8
whataboutbob
AutoX-10/10ths every run
^^ This. Anxiously waiting for the @Whiteline ones to be shipped to me.
Build thread:Here
Old 02-15-2013, 01:37 AM   #9
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
we got these rear camber correction bushings if you dont want to spend money on LCA
http://www.86-zn6.com/WORKS-Rear-Upp...tion_p_61.html
86_ZN6 is offline   Reply With Quote
Old 02-15-2013, 09:52 AM   #10
maxx1957
maxx1957's Avatar
Drives: red
Thanks for the info, probably gonna go with the bushings, are they hard to install??
Old 02-15-2013, 11:11 AM   #11
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Yeah. They can be a rear pain in the butt. You have to press the old bushings out which is the worst part.
Grimlock is offline   Reply With Quote
Old 02-15-2013, 02:50 PM   #12
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Hotchkis Camber Plates. Great for Autocross, track, and daily driver. They come with the crash bolts and offer up to -3° of camber and build in +1° of caster.
http://www.hotchkis.net/scion-frs-su...er-plates.html
Cheers!
-Aaron
Nitro22 is offline   Reply With Quote
Old 02-15-2013, 03:49 PM   #13
Circuit Motorsports
For the Rear, camber arms are really the way to go, the eccentric bushings are the cheaper option but they are a serious pain to both install and adjust.
SPC makes a nice rear arm for a good price, nothing fancy, but it gets the job done. they also make a rear toe arm that works well in conjunction with the camber arm, with those two arms you can get A LOT of adjustment in the rear.
Camber arm - http://www.brz-parts.com/67645.html
Toe Arm - http://www.brz-parts.com/67655.html
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
chanomatik (01-29-2014)
Old 02-15-2013, 03:53 PM   #14
sw20kosh
Cheers!
-Aaron
I wonder if these make a lot of noise. I don't see any rubber in them.
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
MSI Camber plates wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-29-2012 07:16 AM
Camber Plates delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-30-2012 08:17 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
