Old 03-30-2013, 06:48 PM   #1
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
[PSA] (Common knowledge?) Your license plate cover and you.
Well, I swapped my dealer plate covers (I got them to take off the stickers from my car; didn't think about the plate cover), and replaced it with one I that my alumni association had sent me. It's been on for maybe a week now, but it had been rattling whenever I shut the trunk, so I decided to examine it. I noticed some pretty deep scratching on the paint both near the top and the bottom of the cover. Suffice to say, I won't be using it much longer. I suppose tape/rubber/etc. could be used to prevent this from happening, whilst keeping the plate; however, I don't want to risk it.
I don't think I've ever had this issue in the past as all of my previous cars had 4 bolts to keep the plate down, and must have stopped it from moving around and causing scratches. Seems like the plate by itself can cause this issue as well.
Something like this seems like it would be a good. But I think the fact that only 2 bolts can be used still remains an issue.
TL;DR
If you're using a license plate cover/your dealer put one on, remove it, or use something to cover it to prevent scratches.
Mandy is offline   Reply With Quote
Old 03-30-2013, 06:53 PM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Foam or rubber tape solves the problem
86_ZN6 is offline   Reply With Quote
Old 03-30-2013, 07:00 PM   #3
Mandy
Mandy's Avatar
I have two issue with the foam:
1) It's going to attract moisture. Moisture is inevitably going to lead to rust.
2) If it goes on the plate instead of the car, it's going to trap dust and other particles, causing scratching anyway.
3M tape on the car might work, but I'm not sure how something like that would work.
My solution that I'm thinking of now would be to get spray-on rubber, and just spray the entire backing of the plate. I feel like no matter what I do I'm going to lose, and just have to deal with the scratches.
I think a new rear plate holder should be something revised in upcoming model years.
Old 03-30-2013, 07:02 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Your are correct with moisture
My plate has rubber now. Just posted the foam pic just for reference
Old 03-30-2013, 07:07 PM   #5
Mandy
Mandy's Avatar
I just spotted these at Weather Tech:
http://www.weathertech.com/clearcover/
http://www.weathertech.com/clearframe/
Might be worth the $25. It has a rubber gasket on it and it's fairly conservative. It still seems like it may bang around the bottom screws to hold the plate down, but I think I'd trust the rubber to make a good enough seal.
Edit:
Found this illustration; still seems like the metal plate would still cause banging as the rubber isn't between the plate itself and the finish. More research reveals this guy:
Flexy Frame
Says it's for the front bumper, but I'm sure it would work on the rear as well:
Seems ideal.
The Following 3 Users Say Thank You to Mandy For This Useful Post:
13 FR-S Veteran (04-03-2013), 86_ZN6 (03-30-2013), ShoGun (04-02-2013)
Old 03-30-2013, 08:30 PM   #6
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I use closed cell foam weather stripping, work good, doesn't hold moisture, and I've never had any scratching issues. I think it is FrostKing brand.
Cade01 is offline   Reply With Quote
Old 03-30-2013, 08:37 PM   #7
Tucson FR-S
Tucson FR-S's Avatar
Drives: 2013 Firestorm FR-S
I discovered the same problem when I went to put my permanent plate on today, so I ditched the dealer's frame. Since I couldn't find any neoprene washers around, I used rubber hose gaskets to keep the plate off the trunk.
Tucson FR-S is offline   Reply With Quote
Old 03-30-2013, 09:31 PM   #8
FriedRicr
Woop Dee Woop Woop Woop
FriedRicr's Avatar
Drives: Raven 6MT FR-S
massive THUMB!!!!!!
FriedRicr is offline   Reply With Quote
Old 03-31-2013, 04:45 AM   #9
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
I use the same thing on the bottom of the plate. Made up rubber washers from rubber fuel line for the top, just sliced off with utility knife to get the right thickness.
Doesn't retain moisture back there, no rattles and no scratches.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 04-01-2013, 03:28 PM   #10
fiveoneoh
Drives: none
TL;DR
what about using a plastic mounting bracket? It's like a 1/4" thick piece of plastic you put under your plate. It is thick enough to prvent my alumni cover from touching the paint.
Has anyone tried that? I got one from Autozone but my plates haven't arrived yet so I don't know how it will work.
fiveoneoh is offline   Reply With Quote
Old 04-02-2013, 08:35 PM   #11
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Use a Closed Cell Foam to prevent moisture.
l0aded is offline   Reply With Quote
license plate covers, scratches
BRZ tow hook cover hole mod for license plate holder TSY BRZ First-Gen (2012+) — General Topics 19 05-10-2013 02:58 AM
86 License Plate? Saab2Frs Scion FR-S / Toyota 86 GT86 General Forum 8 03-20-2013 03:34 PM
Custom OEM Color License Plate Cover SkitterSkotter Cosmetic Modification (Interior/Exterior/Lighting) 17 01-16-2013 07:30 AM
Need help, plate lamp cover size? 8987846 BRZ First-Gen (2012+) — General Topics 0 12-22-2012 02:00 AM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
