Drives: 2013 86 GTS - Pegasus White
Wheel Directory: XXR 530 18x8.75 +33
![]() Wheels: XXR 530 Size: 18x8.75 Offset: 33mm Colour: Flat Black Tyres: Continental ExtremeContact DW Size: 235/40/18 Springs: Eibach Pro Kit ![]() ![]() ![]() ![]() On a scale of 1-10, my like factor is about 7. There's too much poke up front My biggest dislike is the fact that virtually every other white 86 in my area has black rims
Drives: Whiteout FR-S
Fitment looks good, get some camber bolts to dial in a little negative up front and it will help with the poke.
I have a white car also and don't care for black wheels at all, they seem popular but i just don't get it. You can always paint or powdercoat them a different color because the wheels and fitment do look good. |
#4 | |
Drives: 2013 SWP BRZ
Not knocking your car OP, it looks nice, just something i've picked up on while browsing. Every new wheel that pops up is always black. |
#5 | |
Can you recommend a good camber bolt? Also, judging by the pic above, how much negative camber will be needed? |
#6 | |
#7 | |
Señor Member
Drives: white BRZ 6MT
camber will increase your tire wear but not as much as toe that is out of spec
NW Region Moderator
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
1337
Drives: 2013 BRZ WRB S/C
Add some camber, you'll be much happier with the look. Tire wear will be marginally affected, just make SURE you get an alignment to fix the toe.
#10 |
Drives: Subaru BRZ Limited
The 2nd picture posted is the front poke? Or rear poke?
If that's the front...how does the rear compare? Is there any poke back there?
#11 |
Drives: 2013 FR-S, 2012 MCS
#12 |
Engineering Student
Drives: Scion FR-S 2015
Front car pic PLEASE
There’s no time to stop for gas, we’re already late
| Wheel Directory: XXR 521 18x8.5 +35 | Iddoit2er | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 01-06-2016 12:53 AM |
| Wheel Directory: BBS RG-R 18x8.5 +35 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 04-11-2015 05:03 PM |
| Wheel Directory: BBS CH 18x8.5 +30 | Spaceywilly | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 03-02-2015 02:05 PM |
| Wheel Directory: BBS LM 18x8.0 +50 | stoneman155 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 07-08-2013 08:55 PM |
| Wheel Directory: BBS RE 18x8.0 +50 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-25-2013 09:49 PM |
