Old 03-29-2013, 03:58 PM   #1
ScionFamily
ScionFamily's Avatar
Drives: Magnetic Gray tC, Silver FR-S
Front fender rivets trouble
I'm trying to take of the front bumper for the blackout housing, and the damn rivets on the bottom are not wanting to budge. Please refer to picture:
Any ideas?
Also, sorry if this is the wrong section.
ScionFamily is offline   Reply With Quote
Old 03-29-2013, 04:00 PM   #2
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
its not easy but its not that hard.. take a small screwdriver pop that middle part up once that is up take a larger screwdriver and pry at the larger part.... both flat head screwdrivers
Lee358 is offline   Reply With Quote
Old 03-29-2013, 04:07 PM   #3
SkullWorks
Drives: SSM LT MT BRZ
once mine got some road grime in them I had to spray with some wd-40 type lube to wash out some of the crap. then you take 2 small flat heads and pry where that little recess is between the head and the base equally until it's about 3/16 proud of the large flange, then pull the top with needlenose to remove whole assembly, or pry under large flange with a larger flat head.
SkullWorks is offline   Reply With Quote
Old 03-29-2013, 04:09 PM   #4
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
i had to use 2 flat heads on both sides
GT 86 Brah is offline   Reply With Quote
Old 03-29-2013, 04:23 PM   #5
infinite012
Drives: 13 DGM BRZ Ltd
When all else fails, break the sumbitch. They cost like $0.50 per rivet at any Home Depot and Lowes.
infinite012 is offline   Reply With Quote
Old 03-29-2013, 04:39 PM   #6
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Having the right tools will help you out. These are life savers. That poor body clip looks like you been at it for a while like a dog scratching to get out of his cage haha. This car uses lots of body clips so I suggest investing in these. Several brands make these but I personally have KD. The straight ones and the 90' ones are the ones you will use the most.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
charged86 (03-29-2013)
Old 03-29-2013, 05:03 PM   #7
ScionFamily
Yeah, you would be right I have been working that clip. The under piece wants to keep moving with the upper part of the clip... Its just so frustrating.
Old 03-29-2013, 06:02 PM   #8
AZFA20
AZFA20's Avatar
I wanna say I have actually seen these body clip tools at AutoZone, NAPA, and PepBoys. For just one of em it will run you $15 bucks and even the most stubborn body clips become a 2 second job with these so worth every penny imo.
Old 03-30-2013, 02:45 AM   #9
ScionFamily
I got it thanks though.
Black plastic pop-up rivets tech4pdx Cosmetic Modification (Interior/Exterior/Lighting) 13 07-25-2015 09:23 PM
question about brz/fr-s front fender vents nmullin11 Cosmetic Modification (Interior/Exterior/Lighting) 23 03-20-2013 05:01 AM
FS asphalt driver side front fender Yruyur Exterior Parts (Aero, Lighting, Etc.) 3 02-07-2013 07:46 PM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 11:58 AM
Wanted: drivers side front fender Yruyur Miscellaneous 0 11-26-2012 09:30 PM
