Old 03-21-2013, 11:49 AM   #1
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
TSB's already fixed if purchased after TSB released?
Hi, I should be taking delivery on my FR-S in May sometime and I was just wondering if all the tsb's released for the car will be fixed before taking delivery of the car?
Thank you
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-21-2013, 04:38 PM   #2
HighbreadEH3
HighbreadEH3's Avatar
Drives: 2013 Firestorm FRS, 1993 Civic Si
I am wondering about this also, I purchased the car 3 weeks ago. I haven't had any issues yet......
HighbreadEH3 is offline   Reply With Quote
Old 03-21-2013, 07:02 PM   #3
RedMuck
RedMuck's Avatar
Only factory recalls are required to be done before a retail sale. Tsb's are addressed if a customer has a issue with an item on a tsb. I just got my FR-S out of the shop for the idle issue and it set a few codes P0016,P0017 and P0018 the Scion Service bulleton SSB -0032-12. I am just leaving work so I'll see if all is fixed tonight!
RedMuck is offline   Reply With Quote
The Following User Says Thank You to RedMuck For This Useful Post:
Brody602 (03-26-2013)
Old 03-21-2013, 08:28 PM   #4
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Check your VIN against the range specified in each bulletin if you're having any of the issues covered by each one. There's no reason to even worry about it if your car is problem-free.
Subie is offline   Reply With Quote
The Following User Says Thank You to Subie For This Useful Post:
andrew20195 (03-21-2013)
Old 03-21-2013, 10:36 PM   #5
andrew20195
Drives: 2013 Subaru BRZ
^ This
And yes, generally when a TSB is released, it means the manufacturer has determined a solution to the problem, and it will either be checked at the factory, or newer vehicles will have updated parts designed to address the issue.
andrew20195 is offline   Reply With Quote
Old 03-22-2013, 11:18 AM   #6
Marrk
Drives: Honda Fit
Good question.
Good responses.
Good thread.
:happy0180:
Marrk is offline   Reply With Quote
Old 03-23-2013, 05:15 PM   #7
cocoy_labuyo
Drives: WRB BRZ
where can I check the TSB's?
cocoy_labuyo is offline   Reply With Quote
Old 03-23-2013, 06:00 PM   #8
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
It's in the sticky at the top of this forum.
http://www.ft86club.com/forums/showthread.php?t=21868
hushypushy is offline   Reply With Quote
Old 03-23-2013, 10:12 PM   #9
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
any recall would be performed, but a tsb only applies if you have the problem.
Jesse is offline   Reply With Quote
Old 03-23-2013, 10:42 PM   #10
Noob4Life
86 Noob
Drives: Firestorm FR-S
I bought mine almost two months ago and I think I'm hearing the crickets. Also my idle isn't always stable but I've yet to throw a CEL and I heard its only and issue if you throw a CEL.
Noob4Life is offline   Reply With Quote
Old 03-24-2013, 01:53 AM   #11
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Even though your VIN is not in the range of each specific bulletin, you might still have the issue. My FRS(less than a month old) is going back to the dealer for condensation in taillights issue even though it's vin isn't in the specified range of vins for the condensation taillights. I'm also going to have them look at the chirping noise as well.
Bach415 is offline   Reply With Quote
TSB's performed ravenblackfrs Issues | Warranty | Recalls / TSB 21 03-14-2013 06:02 AM
TSB's & issues thread zoomzoomers Issues | Warranty | Recalls / TSB 6 09-12-2012 12:20 PM
Just Purchased an FRS Blackbeltmma Scion FR-S / Toyota 86 GT86 General Forum 9 07-18-2012 08:10 PM
Did anyone purchased? V1B Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 06-12-2012 08:32 PM
Another BRZ Purchased Deslock BRZ First-Gen (2012+) — General Topics 12 06-08-2012 10:26 PM
