Old 03-21-2013, 09:58 AM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Test pipe questions
Welcome! Just had a few questions on test pipes in general. I searched test pipe and got some basic info but mostly found out who makes them lol.
I was wondering where exactly does the pest pipe go? Does it connect the front to the catback?
Aside from increasing airflow (hopefully) how much does it change the tone of an exhaust setup?
And last on a few setups I saw it said test pipe available on manual only? Why?
Thanks.
bdanisi is offline   Reply With Quote
Old 03-21-2013, 10:02 AM   #2
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
The test pipe connects the overpipe to the catback, eliminating the OEM 2ndary cat.
It will make your exhaust loud and might give you a bit of rasp.
There are test pipes available for both manual and auto, just have to do your research. Some are universal some are not, reason being there is less space in automatic cars, for example if you wanted a helmholtz resonator
shu5892001 is offline   Reply With Quote
Old 03-21-2013, 10:25 AM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Simply put, a test pipe is a pipe that replaces a catalytic converter. Like this
Left test pipe/Right Catalytic converter
LeeMaster is offline   Reply With Quote
Questions about Nameless Front pipe with Helmholtz Resonator Xdragonxb0i Engine, Exhaust, Transmission 67 08-28-2016 12:47 AM
ark test pipe? ft86me Engine, Exhaust, Transmission 1 02-24-2013 02:34 PM
test pipe ft86me Engine, Exhaust, Transmission 21 02-24-2013 02:45 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Test Drive & Questions Sambalam AUSTRALIA 7 07-06-2012 05:23 AM
