Any mags from other Scions or Subarus fit a FR-S
Are there any mags from older model Scions or Subarus that would fit a new Scion Fr-S? I wanted to pick up some used mags to put winter tires on. Not sure what would fit. Anybody have any suggestions?
Drives: Subarus
like magazines...? is mag slang for wheel in quebec? the car is 5x100. the 1st gen tc and all subarus except 05+ sti share the same bolt pattern.
Automatic Hooligan
As mentioned, tC1 wheels will fit or can be made to fit fairly easily. There's a thread here of a member that put them on his car. They are the correct bolt pattern (5x100) and are very close to the stock wheels in size (17x7) and offset (+45).
Drives: 01 MR-s, 78 280z, 13 FR-s
They're only mags if they're made from magnesium. Not a very common wheel material.
#5 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Scroll down to the OEM section to answer your question |
One thing to keep in mind is hub bore. HB size on the twins is 56.1mm.
Subaru standard hub bore is 56.1 mm, so OEM Subaru should be fine (if bolt pattern matches and offset fits). Scion standard hub bore is 54.1, so you'll need to machine out the center by 2mm to get these to work.
2022 BRZ Build 2013 FR-S Build |
Thanks for the input guys. I will make sure to use the term wheels instead of mags.
This thread is awesome. Thanks!
#9 | |
I meant the above thread is awesome. |
| Tags |
| fr-s, mags, wheels |
| First Coast Scions | Dam262a | Southeast | 38 | 04-04-2014 05:18 AM |
| Changing mags? | Kev01 | AFRICA | 10 | 11-30-2012 10:54 AM |
| about scions.. | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-28-2012 09:42 AM |
| Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? | HitTheGas | BRZ First-Gen (2012+) — General Topics | 12 | 02-21-2012 01:24 PM |
| Scions FR-S page | hartnsol | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 12-05-2011 03:05 PM |
