Old 03-19-2013, 10:48 PM   #1
frsguy707
frsguy707's Avatar
Weapon R Intake...
Hi guys I just wanted to let you all know about the new Weapon R Intake System. I've had this on my car for quite awhile now and I have noticed a big difference in performance and power.The final product is finally available for purchase and we are in the process of dynoing soon so we know exatcly what the power gains will be. If anyone has any questions just let me know and ill try to answer them for you, but in the mean time here are a few pics please let us know what you think
frsguy707 is offline   Reply With Quote
Old 03-19-2013, 11:27 PM   #2
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Could someone please explain this to me.
It looks like it's using the stock snorkle and just put a pod filter in the same location as the stock air box.
Is there going to be any gain from this?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-19-2013, 11:47 PM   #3
frsguy707
frsguy707's Avatar
I believe it doesnt make any difference with the stock snorkel I just havent remibed it seeing as I havent had time to take off my bumper. And were still waiting fo r the gains
Sent from my SPH-L900 using Tapatalk 2
Old 03-20-2013, 12:02 AM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I think the gain will be from the tube design, not the filter design.
The design causes a three stages of air flow to occur - turbulent at the filter base / meter > laminar through the tube > turbulent at the throttle body
Im assuming the design allows for a "smooth" transition at the 90* bend before it enters the engine. The stock mess causes oscillations that amplify certain frequencies in the multiple resonators but is also a more "turbulent" transition into the engine from the filter.
This is why I believe the injen intake makes as much power as it does - it forces the meter to read highly turbulent flow because of the chamfer before the meter.
I like this design. Some will be ape shit paranoid about intake temps though. I suggest leaving the stock snorkel to help induction of ambient temp air.
supramkivtt2jz is offline   Reply With Quote
Old 03-20-2013, 12:11 AM   #5
zooki
Drives: waiting on a 2021...
Just from eyeballing it, it looks like the piping is larger than stock. If you put the AFM in a larger than stock pipe, it will read less airflow than there actually is, and lean out the fuel mixture, correct? Be interesting to see the air/ fuel logs on the dyno.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-20-2013, 03:52 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
This:
....and the probability of heat soak would mean this is a no-no for me.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-20-2013, 03:57 AM   #7
Lonewolf
Lonewolf's Avatar
Drives: Moped
Must...resist urge to...bring up the past....weapon r is....
Old 03-20-2013, 04:06 AM   #8
NickFRS
Drives: 2013 Asphalt FRS
Weapon R has always been garbage
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-20-2013, 08:59 AM   #9
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
As long as the tubing at the MAF is the same diameter as stock there will be no major issue. Errors and false readings at the MAF will be attributed to non-uniform flow characteristics (injen intake)
Old 03-20-2013, 09:36 AM   #10
frsguy707
frsguy707's Avatar
As far as I know the MAF is exactly the same diameter as the stock.
Old 03-20-2013, 12:06 PM   #11
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
It is cool looking intakes... i know that premier autowerkz sold weapon r stuff in my country... if this gains good powerband without a tune (auto tranny) i would like to have 1 installed...
dokterdewe is offline   Reply With Quote
Old 03-20-2013, 04:29 PM   #12
DriftEightSix
Pegasus White
Drives: 86
Thank you good sir for taking the time to write this sweet ass explanation
Old 03-20-2013, 05:29 PM   #13
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
No problemo - aerodynamics and flow properties are essentially what i went to school for.
Another kinda cool thing i just noticed about it is that the bell shape from the 90* tube to the throttle body silicon connector acts as a velocity stack of sorts. This allows for an even smoother transition into the engine.
[ame="http://en.wikipedia.org/wiki/Velocity_stack"]Velocity stack - Wikipedia, the free encyclopedia[/ame]
Old 03-27-2013, 12:39 AM   #14
nb2005
Drives: Scion FRS
Looks like the 90 deg bend pipe size is bigger than 3", otherwise, it doesnt need to step down when it's closed to the TB...
nb2005 is offline   Reply With Quote
Weapon R headers, intake, muffler delete brichard0625 Engine, Exhaust, Transmission 59 10-30-2015 03:00 PM
Secret Weapon-R Intake?? scionfr_s Engine, Exhaust, Transmission 38 11-01-2014 01:35 PM
Control Your Thorttle Output with the Weapon R I-Throttle Controller !! PRO Import Tuners Engine, Exhaust, Bolt-Ons 16 08-14-2012 07:10 PM
