Old 03-19-2013, 01:54 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
DIY Keyport slide replacement key
If you've never heard of the keyport stop now and head over here: http://mykeyport.com/
It's a keychain replacement that works very well. Holds 6 keys, or 5 plus automotive chip. It's badass.
So if you want to use this with your 86 you'll need some things.
Keyport Slide
Blade #TR47
Automotive chip insert (without the chip, you'll have to call and ask for it)
A donor key (valet works best)
Very sharp razor blade
This is what it looks like in the ignition.
Here you can see the size differences.
Take your time and slowly slice along the edge of the key and pry it open with a screwdriver.
You can start to see the chip. Cut that little bugger out.
Here it is out of the plastic.
Now put it into the vacant space, mine is occupied because I'm swapping it from a different vehicle. And that's it!
Get your blank cut by a good locksmith and you'll be good to go! DO NOT USE THE VALET KEY TO GET CUT OR YOU WON'T BE ABLE TO OPEN YOUR TRUNK!
post_break is offline   Reply With Quote
Old 03-19-2013, 02:55 PM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I've heard bad things about these. Lots of problems with keys breaking, and the immobileizer not being able to read the chip.
Old 03-19-2013, 03:15 PM   #3
post_break
post_break's Avatar
I've used it for 2 years now with not a single issue. Never had a car refuse to start either.
Old 03-19-2013, 03:16 PM   #4
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Its like those large pens with 4 or more colors built inside that allows you to select the color or the pen by flicking a button.....except for adults.
Old 03-19-2013, 04:17 PM   #5
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
it looks like those giant USB sticks when they first came out in 2003.
i thought the trend for car keys is smaller the better, so you don't have to stick a brick in everytime you drive.
chenshuo is offline   Reply With Quote
Old 03-19-2013, 04:28 PM   #6
infinite012
Drives: 13 DGM BRZ Ltd
I could see this being useful for people who have multiple vehicles with multiple keys and keyfobs on their keychains. This would become heavy and cumbersome if you had, say, more than 2 car keys on a single keychain.
infinite012 is offline   Reply With Quote
Old 06-10-2014, 09:52 PM   #7
kowasu.mono
kowasu.mono's Avatar
Drives: 2013 Subaru BRZ Limited (GBS)
Sorry to bump an old thread. When you transferred the chip, did you use glue to make sure it didn't fall out?
kowasu.mono is offline   Reply With Quote
Old 06-11-2014, 11:30 AM   #8
jonzhuxD
Drives: Ultramarine FR-S
By the looks of it, you only have to extend the piece with the chip in it to swap it with another one, looks like you never have to extend it with normal use so I wouldn't glue it.
jonzhuxD is offline   Reply With Quote
Old 06-11-2014, 02:29 PM   #9
kowasu.mono
The slide doubles up as a barcode reader. As a result, the slide goes through prolonged used. I'm just curious as to whether the chip needs to be secured or the mounts hold the chip properly in place.
Old 09-22-2015, 09:41 PM   #10
sgtcarrot
Drives: Scion FR-S 2015 Blue and stock
Just did this with my key, converted to Rav4 or Corrolla key, not sure. I have a 2015 FRS, and the key is different from all of the ones I have seen here. Its a little nicer, but still the Camry key, and I wanted the flip.
Took my time removing the chip: used a stiff blade box cutter, heated it up on medium with a heat gun and cut the external wall of plastic. Then put the box cutter blade behind the chip and it popped right out.
My local locksmith cut the key for $3, and the fob cost to me was $12. Thrilled with the result.
sgtcarrot is offline   Reply With Quote
windshield replacement ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 28 02-17-2013 03:08 AM
speaker replacement 20valvewynn83 Electronics | Audio | NAV | Infotainment 3 12-12-2012 02:36 AM
Great slide from yesterdays Solo Event naikaidriver FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 12-11-2012 07:31 PM
Slip'n Slide! BuBlake Scion FR-S / Toyota 86 GT86 General Forum 45 10-03-2012 07:55 AM
Any new owners try an E-Brake slide yet? Space Boy Matt Scion FR-S / Toyota 86 GT86 General Forum 4 06-12-2012 03:14 AM
