Old 03-18-2013, 06:31 PM   #1
wootwoot
Drives: FRS
Spring/Struts or Ground Control?
I am trying to figure out what I want to do suspension wise and was hoping for some advice. Here goes:
The car is really a weekend car. It may become my everyday driver at some point but right now I only drive it on the weekends and nice days. It will see HPDE's a few times per year. It may see some autoX here and there, but just for fun. Maybe a drift event... etc. I want a solid set-up, durable for everyday driving and fast enough to keep up with the higher power cars at the track (given the driver is up to the task). Adjust-ability is not that high on my priorities. I won't be changing alignment or ride height after the initial install. I am hoping to set it and leave it alone. I will adjust sway bar settings and dampening but that is about it.
Given all this, I am trying to decide between these two set-ups:
Set-Up 1:
Race Comp yellows
Koni insets
Whitleline Comp C's
About $1100
Set-Up 2:
Ground Control Street Coilovers with Bump Stops
About $1400
Each will have alignment parts and sway bar upgrades.
So which one would be better given my use? I am thinking the spring/strut combo would be better at the moment as I don't need the height adjust-ability the Ground Control's give. I also get the Comp C's and could buy a sway bar with the money I save. Am I missing something about the Ground Control's? Can I get a more aggressive spring/shock with Ground Control? Don't they use the same Koni Inserts that everyone else gets?
Thanks guys,
Wootwoot
wootwoot is offline   Reply With Quote
WTB Ground Control System Xdragonxb0i Brakes, Suspension, Chassis 0 03-05-2013 04:55 PM
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 07:56 PM
Considering the Ground Control Setup dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 11-14-2012 01:05 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 05:08 PM
Ground Control is working on some stuff for us :) D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-24-2012 06:21 PM
