Old 03-17-2013, 04:50 PM   #1
ft_sjo
Drives: GT86
Turbo/SC Kits Comparison Chart
Threw this together. Power graphs based on dyno data posted on this forum. No crazy modifiers made for 'low' or 'high' reading dynos. The purpose it to show characteristics of the conversions/kits rather than precise numbers. If you don't understand this, don't post. Y axis set at 300 for the most relevant comparison.
Which one do you like? I think the FBM Stage 1 is the best all rounder. An extra 20-30 ft-lb below 4k would be nice.
Old 03-17-2013, 05:24 PM   #2
Mitch
form follows function
Drives: RIP '13 BRZ
I would suggest setting y-max to include the big kits and just having a taller chart. We all know they go into the stratosphere on power, but you can show it without screwing up the comparison on raw power. If you wanted a tighter grouping, you could show hp/$ curves as a separate chart to show different but relevant data.
Mitch is offline   Reply With Quote
Old 03-17-2013, 05:28 PM   #3
Gen
Drives: Scion FR-S
FB's stage 1 kit is more like $4600 btw. Their "premium" kit is 6k.
Gen is offline   Reply With Quote
Old 03-17-2013, 05:51 PM   #4
stilletto
Drives: 2008 Mitsubishi Eclipse GS
Still looking forward to PTUNING's Kit.
stilletto is offline   Reply With Quote
Old 03-17-2013, 06:02 PM   #5
diss7
Drives: AE86, 2x GT86, TE27
I think it would also be benefical to include potential common motor swap dynos? I've come to realise that no FI kit on the boxer is going to deliver what I think will make a good daily. I think once a few more have done a 2GR-FSE conversion, and all the weight and ecu/electronic details are understood, this will become a common conversion.
Heres a rough dyno....
diss7 is offline   Reply With Quote
Old 03-17-2013, 07:22 PM   #6
dabocx
dabocx's Avatar
Drives: Scion FRS
Originally Posted by Hempo View Post
Dont know where to post this and since i am new to the forum i am not allowed to post a new topic.. i have a MT BRZ which i would love to crank up the WHP to 300-350 area. There are LOADS of kits as anyone can see.. but which kit can give what i am looking for? I already have the full Agency power exhaust complete with header and everything. I am well aware that i have to upgrade fuel pump, injectors, clutch etc.. but what kit turbo or SC makes 350whp without problem?
On 93 pump gas thats not likely to happen without building a motor.
On e85 the JDL/FBM/Ptuning kits will get you there easily.
dabocx is offline   Reply With Quote
Old 03-17-2013, 08:34 PM   #7
2forme
I feel like this chart should be torque, rather than horsepower.
Old 03-17-2013, 08:43 PM   #8
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
A separate TQ chart would be nice.
cmss2000 is offline   Reply With Quote
Old 03-17-2013, 08:48 PM   #9
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
I feel like P&L and D3 should be added. Looking forward to the Ptuning kit on corn
NomoreNA is offline   Reply With Quote
Old 03-18-2013, 03:08 AM   #10
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
i want to see gas consumption on each of these systems, i don't want to think i'm driving my 6series again.
Zardoman is offline   Reply With Quote
Old 03-18-2013, 06:08 AM   #11
NorCalRider
Drives: 2009 Toytoa Tacoma 4x4 Dbl Cab LB
I find it hilarious when people ask about fuel mileage on a turbo/sc kit. The mileage is dictated by you right foot. If you stay out of boost it will be as good as stock and in some cases better then stock. The minute you go in to boost you will be using more fuel. Forced induction forces more air into your engine and requires more fuel to complete the burn process to create more power. Mileage is all up to you as a driver.
2013 SWP BRZ Limited(on order)
2012 Vw Jetta Sportwagen TDI 6mt Navi and Pano
2009 Toyota Tacoma 4x4 Double Cab Long Bed
1994 Honda Civic HB TurboCharged Track Car
NorCalRider is offline   Reply With Quote
Old 03-18-2013, 10:06 AM   #12
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Continuing the off-topic discussion. Consider the average 86 buyer. They want power (jdm powah if possible), but don't want to get 20 mpg during highway cruising.
If the AFR is proper (on and off WOT), and the system uses DI effectively (major assumptions)... a "big turbo" kit won't be capable of running into boost if you drive like a grandma (< 3000-3500 rpm). Generally, you'll see a slight improvement in fuel economy. I'd guess this is because the slight spin of the turbo relieves pumping losses and air temperatures are higher.
When you hit the rev range (really it's an exhaust flow rate) that boost is available, you effectively turn on an extra row of cylinders. You don't necessarily have to use the available torque, but it's there.
A "small turbo" kit is the same... but you add on less cylinders at lower engine speed (exhaust flow rate). If you're cruising down the highway, it's pretty likely that you're atleast at half of your max boost pressure. This means you've got more available torque and the potential for worse fuel economy.
Fuel economy is really about air flow and AFR. If you keep RPMs and LOAD low, air flow is low. If you're tune is in an efficient zone (and closed-loop mode is operational), AFR will stay high.
Can any of the gurus classify these kits as "big" or "small" for us? FBMv2 is fairly big, AVO is fairly small, right?
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-18-2013, 10:12 AM   #13
ft_sjo
Drives: GT86
Thanks for the comments everyone. This was just a rough idea that I may look to develop. I'm trying to find an easy way to add new results into a system and have the ability to easily click a few buttons to do a comparison, for example. I don't really have the time to do any development on this and doing it in excel/googledocs isn't really going to work.
If anyone knows an off-the-shelf system which can dynamically produce graphs and offer a comparison feature (effectively enabling/disabling series data on the fly) then let me know.
I know a chap was creating a dyno database. I'll try to find the URL, not sure if that did graphs either or just stored the images from the dyno tests.
Old 03-18-2013, 10:26 AM   #14
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Great post.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 09:14 PM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 08:27 AM
Turbo Kits: Rational boost threshold yet? Ryephile Forced Induction 88 01-22-2013 12:05 AM
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! Lisa@TrueStreetIndustries Exterior Parts - Lighting 129 01-18-2013 08:57 PM
