Old 03-16-2013, 01:48 PM   #1
Vorynn
Drives: 2013 BRZ Limited (GBS)
Question Noobie advice: optimal shift patterns?
I'd like to get some advice on which RPMs to shift at and generally run at for both performance and mileage, along with some minimums for car health.
My BRZ is currently at 500 miles, so I'm trying to play nice for another 500. At this point my main worry is that I may actually be driving at too low of an RPM sometimes. My previous car was a MINI that was very happy to go up hills and generally drive in the city at 1500-2200... before that I had a Civic del Sol which was happiest between 2k-3k. The BRZ doesn't seem to like me very much below 2200, though, and when accelerating, below 2500 seems clunky. Is even that too low? Lately I've been trying to make sure that I only upshift above 2900 (so that I will be around 2500 after shifting) unless I have reached my cruising speed.
Maybe I'm treating this 4k cap as too much of a dampener across the boad, I dunno :P What would you say is the optimal shift pattern, and how should it differ during break-in? after break-in, is it normal to stay above 4000 quite often?
I've been searching around for info both here and on the internet at large, but this particular question eludes me I'm not too proud to take advice from the experts about my new car, so have at it...
Vorynn is offline   Reply With Quote
Old 03-16-2013, 02:06 PM   #2
Ahernandez0909
Ahernandez0909's Avatar
Drives: '13 Asphalt FR-S M/T
I'm a noob too but before break in I always shifted at 2500 and I would stay at 3k up hill. And now I'm always at 4k. It's just more fun that way. But later when you wanna redline it you'll see how the car performs after 4500 rpm. It's like a whole nother car.
Yes, yes that is a Scion.
Member Journal
Ahernandez0909 is offline   Reply With Quote
Old 03-16-2013, 02:08 PM   #3
spyingwind
Drives: White '17 86
I shift when I see the red flashy light.
No but seriously, I shift dependent on what my needs are at the moment. Do I want to accelerate fast right now? Red light!!! Do I want to cruise, shift at about 3k-4k.
I red lined it after I got it off the lot.
spyingwind is offline   Reply With Quote
Old 03-16-2013, 02:17 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
You can turn on the gear indicator so it'll tell you when to upshift for optimal fuel economy.
JDKane527 is offline   Reply With Quote
Old 03-16-2013, 02:22 PM   #5
SloS13
Drives: 2013 FR-S whiteout
If you're thinking about it too hard, you're doing it wrong.
For mpg, watch your MPG gauge. It's semi-accurate.
SloS13 is offline   Reply With Quote
Old 03-16-2013, 02:43 PM   #6
whaap
whaap's Avatar
There are always exceptions, but as a general rule under normal driving conditions I use the window between 2,000 rpm's and 3,000 rpm's as my indicator for when to shift. If I get down to 2 I down shift. If I get up to 3 I will upshift. As I said, depending on conditons (uphill, downhill, etc.)
whaap is offline   Reply With Quote
Old 03-16-2013, 02:52 PM   #7
radroach
Drives: car
In traffic, I shift 1st - 2nd at low mph, and then drive regularly. Below 10mph you can easily shift to 2nd without needing much rev matching:
1st gear slowly engage clutch and just enough throttle to move with enough momentum past 7mph, clutch back in, shift to 2nd and ease it out, you should be at the correct RPM to shift at this speed without needing to rev match, and then drive normally.
Old 03-16-2013, 02:54 PM   #8
CBR600RR
Drives: Raven Black
What RPM should you shift at????
Ummmm, pick one.
Old 03-16-2013, 03:45 PM   #9
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
I shift based off feel and sound... When I'm playing nice I shift earlier than when not but I couldn't tell you which RPM I'm shifting at regularly.
Chewie4299 is offline   Reply With Quote
Optimal Wheel Size for Stock Power Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 110 06-09-2016 10:08 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
optimal RTR setup scottynoshotty Tracking / Autocross / HPDE / Drifting 28 03-03-2013 01:05 AM
FR-S Noobie Q's steve87j Scion FR-S / Toyota 86 GT86 General Forum 23 01-05-2013 09:24 AM
Optimal tint (California mostly) Oriental Life Southern California 49 08-17-2012 07:05 PM
