Old 03-16-2013, 01:28 PM   #1
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
new to tuning, who to go with?
Did a little research on the forums and noticed there are plenty to go with.
I'm leaning on visconti, but here are my plans.
Im currently running a drop in filter because I'm not going to waste money on a intake system that does nothing.
Im also running a full header back. Motiv overpipe and hfc and perrins' unres catback.
I might go supercharged in the future, but I want to wait and check out my options and get a game plan.
I would like something easy to use that wont blow upp my car. And no, im not trackin right now.
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 03-16-2013, 03:53 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've only tried Visconti but I've had zero issues and highly recommend this tune.
Old 03-16-2013, 04:06 PM   #3
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
how do you go about getting the tune? did you go to a shop? does it plug into the car and you drive with it so the tune learns the car ? rookie over here too but did a little research
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-16-2013, 04:07 PM   #4
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Go to a local reputable tuner if at all possible. The drift office should be local to you, they seem to have some solid results on this platform comparable to any of the other tuners here.
industrial is offline   Reply With Quote
Old 03-16-2013, 04:26 PM   #5
Calum
That Guy
If possible a tune made to order would be best.
How you get a tune from Visconti is you pay him, he sends you the hardware, a flash drive and obd2 to usb cable, you then install somesoft ware onto a windows laptop, then you email him and he sends you the tune. You use the cable and laptop to load it into your ECU. I was nervous the first time because Ive heard horror stories but Ive never had an issue. The very few that have were taken care of very quickly by both John and Ecutek.
Sent from mission control
Old 03-16-2013, 04:29 PM   #6
stilletto
Drives: 2008 Mitsubishi Eclipse GS
You may have to repeat that process a couple of times, as they may have to "tweak" the tune a bit to optimize it for your specific car.
stilletto is offline   Reply With Quote
Old 03-16-2013, 05:02 PM   #7
Vukodlac
Vukodlac's Avatar
Alright that kinda gives me a good start on where to go. So far I have touched base with a local performance shop who installed my exhaust.
We talked about it a little, but we pretty much talked about all the risks associated with tuning. Not to scare me off, but just to let me know what happens with some folks cars. Especially, when they dont know what they are doing and fry their ecu...yikes
Ive hearg pretty good things about visconti, however. I would like to see how much cost all this crap entails and if its worth it, or just hype.
-2013 Scion FR-S-
K&N drop in.
Old 03-16-2013, 06:19 PM   #8
Rich@ViscontiTuning
Drives: 2012 VW GLI
Here's how you purchase the flash from Visconti Tuning. I've posted both the pump gas only kit and the pump gas + e85 kit. Both kits include the cable, the license and the maps - everything you need to perform the tune yourself.
If you have e85 in your area, then you'll absolutely want to get the kit that has both the pump gas map and e85 map. The e85 map will give you about 25-30 whp, so it's much better to take advantage of e85 if it's available in your area .
Here's a run down of the four maps you'll get and their features (applicable to both pump gas and e85 maps):
Map 1 - Tune + Stock Rev Limiter
Map 2 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting
Map 3 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting + RaceRom Traction Control
Map 4 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting + More Agreesive RaceRom Traction Control
And below this, are links to purchase the packages. Let me know if you have any questions!
http://="https://www.paypal.com/cgi-...hipped to USA)
-Rich
Rich@ViscontiTuning is offline   Reply With Quote
Old 03-16-2013, 06:24 PM   #9
Rich@ViscontiTuning
Drives: 2012 VW GLI
Links aren't posting from tapatalk. I'll post when computer is available.
Old 03-16-2013, 06:25 PM   #10
Pandle
Drives: CBS BRZ
Click here for STG1 Pumpgas ONLY - (Shipped to USA)
Click here for STG1 Pumpgas + Ethanol - (Shipped to USA)
-Rich
Fixed your links
Pandle is offline   Reply With Quote
Old 03-16-2013, 06:25 PM   #11
Vukodlac
Vukodlac's Avatar
Hi rich,
Im not sure about e85 in the seattle area. But, when you make that convertion doesnt o e have to replace all their fuel system components to run the E85?.
On my phone, links are not working for me atm.
I hear replacing the fuel system is not cheap. Could be wrong though.
-2013 Scion FR-S-
K&N drop in.
Old 03-16-2013, 06:26 PM   #12
Rich@ViscontiTuning
Drives: 2012 VW GLI
Originally Posted by Pandle View Post
Fixed your links
Thanks! Lol
Old 03-16-2013, 06:27 PM   #13
Rich@ViscontiTuning
Drives: 2012 VW GLI
Originally Posted by Vukodlac View Post
Hi rich,
No modifications are required. Just make sure it's an empty tank before you fill with e85 (and switch maps).
Old 03-16-2013, 06:30 PM   #14
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Funny thing about our cars (FRS/BRZ), no fuel system changes are necessary to run e85. While the long-term effects haven't been tested..(i.e. the car has only been out for 10 months or so), the only drawback seen from e85 so far has been a loss of mpg. So no worries about additional costs for fuel system. Just need the right tune to run it.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
Anyone into DIY ECU tuning? Saibot Engine, Exhaust, Transmission 26 04-25-2012 01:16 PM
Tuning Jordo! Engine, Exhaust, Transmission 54 09-05-2010 05:29 PM
