Old 03-07-2013, 01:48 PM   #1
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Want a drop without losing ground clearance
So far the least aggressive drop i see is the eibach pros i believe? I just want to get rid of the wheel gap with 18 inch wheels will I negate the ground clearance lost on the drop??? any other spring recommendations for maybe even a smaller amount of drop?
eddieEndo is offline   Reply With Quote
The Following User Says Thank You to eddieEndo For This Useful Post:
Anthonytpt (03-07-2013)
Old 03-07-2013, 02:05 PM   #2
Racecomp Engineering
Our RCE Yellow springs lower a hair less than Eibach Pro-Kit. 20mm drop front and rear, just under an inch. We also include replacement bumpstops like Eibach. Lots of happy customers.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Anthonytpt (03-07-2013), ATL BRZ (03-07-2013), Beyer Subaru (03-07-2013), eddieEndo (03-07-2013)
Old 03-07-2013, 02:06 PM   #3
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Quick and dirty math shows a 235/40/18 would be aprox 20mm taller than the stock wheel/tire combo.
That would be only a 10mm drop in ground clearance with the RCE Yellows.
Chimpo is offline   Reply With Quote
The Following 2 Users Say Thank You to Chimpo For This Useful Post:
Anthonytpt (03-07-2013), eddieEndo (03-07-2013)
Old 03-07-2013, 02:36 PM   #4
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
awesome i willbe contacting u guys as soon as i get some wheels , hate wheel gap but my driveway is steep and my speed bumps are ridiculous
Old 03-07-2013, 03:05 PM   #5
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Lemme guess, you want your cake & eat it too? Lol
Seriously, even with 18s, you'll need to make concessions one way or the other.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-07-2013, 04:31 PM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
+1 for RCE Yellows
Old 03-07-2013, 06:06 PM   #7
tisb0b
Drives: Grey GT86 MT
Your math is off, stock is 215/45/17 to move to an 18" rim typically you'd run 225/40/18 to maintain speedometer accuracy. 10mm extra width is not going to result in 20mm taller than stock. Going with 225/45/18 could work at the expense of speedometer accuracy.
tisb0b is offline   Reply With Quote
Old 03-07-2013, 07:26 PM   #8
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Yep. @Racecomp Engineering knows what their talking about.
Beyer Subaru is offline   Reply With Quote
Old 03-07-2013, 07:35 PM   #9
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
His math is slightly off but it's almost there. A 235/40-18 has a diameter of 25.4 inches and the stock 215/45-17's have a diameter of 24.6 inches. That's a total diameter difference of ~20mm. But, only half of that contributes to ride height, so it would bring it back up 10mm for a 10mm total drop.
Either way, the speedo is jacked and the car is going to be more sluggish as the gearing has been altered.
Changing tire size to compensate for ride height is not the greatest idea. Either deal with a lower ride height or deal with the gap, or find some compromise between the two (mild drop) that makes things livable. Screwing up the gearing and speedo isn't really a good option.
Nathan
SubieNate is offline   Reply With Quote
Old 03-08-2013, 08:11 AM   #10
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
He never asked about speedo accuracy. Obviously going from 625.3mm dia (stock) to 645.2mm dia (235/40/18) would goof it, but that wasn't his question.
I'm losing it. How did you cope? Kyubi Scion FR-S / Toyota 86 GT86 General Forum 56 01-09-2013 02:20 AM
How much ground clearance after Racecomp springs? Bleevin CANADA 1 01-08-2013 02:10 AM
Ground clearance? RT87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-28-2012 04:13 PM
Losing hvac lighting? SemperFi Electronics | Audio | NAV | Infotainment 0 11-01-2012 12:36 PM
Lowered Car, Losing traction while getting off drive ways 86_ZN6 Scion FR-S / Toyota 86 GT86 General Forum 54 10-26-2012 10:02 AM
