Old 03-05-2013, 12:37 PM   #1
Kamakanani0
Kamakanani0's Avatar
Drives: Scion FRS (RAVEN)
Bluetooth problem stock unit
Has anyone had any problems with the stock stereo Bluetooth lately? The past couple weeks it either says I'm connected in the settings but says no Bluetooth, and every now and then it skips! Like as if its playing a CD with scratches and won't play straight. The only solution I found is turning the car off and turning it back on. Anyone else having this problem?
Philippians 4:13
Kamakanani0 is offline   Reply With Quote
Old 03-05-2013, 07:37 PM   #2
ASdispatch
Drives: GBM Subaru BRZ
I had the problem today, I turned off the Bluetooth from my phone then reconnected.
ASdispatch is offline   Reply With Quote
Old 03-06-2013, 06:29 PM   #3
iaclimber4
iaclimber4's Avatar
Drives: 2013 Whiteout FR-S MT
i've had the same thing. It doesn't happen everday, but usually the ipod connects, then disconnects. When i go to re-sync the bluetooth, the menu only has two options (when pressing the main button), which include SSP and Audio (bass/treble, etc...). Usually there is a bluetooth option which allows a manual sync, but that doesn't show up. The only way to reset is to turn off the car. Turning off the head unit doesn't do anything....
iaclimber4 is offline   Reply With Quote
Old 03-06-2013, 06:32 PM   #4
Asphalt~86
Drives: Asphalt AT
Yeah I think this is just a fault in the system. Has happened to me multiple times. I have only had success turning the car off and turning it back on. Even if I diconnect BT or restart my phone it still will be messed up.
Asphalt~86 is offline   Reply With Quote
Old 03-08-2013, 12:52 AM   #5
sol740
The only issues I have with the bluetooth are the random volume/control lockouts from the BTA showing it's paused when it's damn well not. Annoying. Especially when you are blasting some loud DnB/Dub and you pull up to a drive through and start rolling down the window and turning the volume knob, only to find out it's stuck blasting bass wobbles into the drive-through microphone, while you dig into your pocket trying to get to your phone to kill the music.
Then you just straight bail, staring at the bewildered person in the window as you pass, and realizing there's a power button on the radio.
I assume.
sol740 is offline   Reply With Quote
Old 03-21-2013, 12:27 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I am having this same issue. This morning I even restared the car and it didn't fix the problem. Fails to connect and then no opton to manual sync, even when in park. i think I'm gonna take it in to the dealer as it is really annoying and now that i know I'm not the only one. When did all of you get your cars? Maybe we can figure out a time frame for the production of the issue. Got mine in May 2012.
Ill come back and post after I take it in.
Old 03-21-2013, 12:42 PM   #7
Archavious
Drives: Subaru BRZ
Are you connecting with an Android 4.2 device? There is a bug with android's bluetooth audio that can cause this.
http://code.google.com/p/android/issues/detail?id=39633
Archavious is offline   Reply With Quote
Old 03-21-2013, 04:27 PM   #8
finch1750
finch1750's Avatar
Im on 4.0. also, that wouldn't affect the HU not having BT options on the menu like the problems described here, just that phone trying to sync.
Old 03-21-2013, 04:42 PM   #9
WRB_BRZ
Drives: 2013 WRB BRZ
I have an iphone 5 and this happems to me once in a while.
Restarting is the main solution or i just manually reconnect with the phone but when i do that i can't change somgs off the head unit i meed to manually do it with my phone.
And i got my brz December 23rd if that helps
WRB_BRZ is offline   Reply With Quote
Bluetooth causing head unit to reset? Eric1855 Electronics | Audio | NAV | Infotainment 4 01-15-2013 09:42 PM
FR-S stock Pioneer head unit and Driod Razr problem JayNutter Electronics | Audio | NAV | Infotainment 1 10-09-2012 09:52 PM
FR-S Pioneer Base Unit with bluetooth phone NMMI89 Electronics | Audio | NAV | Infotainment 4 09-19-2012 12:11 AM
Bluetooth and stock unit question Brimford Electronics | Audio | NAV | Infotainment 1 07-21-2012 04:44 PM
Bluetooth built into head unit? finch1750 Electronics | Audio | NAV | Infotainment 8 06-16-2012 03:59 PM
