Old 03-03-2013, 04:35 AM   #1
victorb
Drives: Black 86
Front pipe
Hi guys, I recently installed the greddy sp elite. Now, I am planning to change the front pipe, the invidia resonated cat less or the Megan cat less
Car mods: Perrin drop in and greddy sp elite axleback.
I've been reading two threads (fa20's post zn86's post). Currently confused if I still do it as it will make the a/f richer thus decrease in HP.
I don't plan to have it tuned.
Your Inputs will be appreciated
victorb is offline   Reply With Quote
Old 03-03-2013, 05:20 AM   #2
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
In the same line of thought, does anybody know which pipe makes the most hp?
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 03-03-2013, 12:58 PM   #3
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Worries about performance but doesn't want a tune.
SubaSteve is offline   Reply With Quote
Old 03-03-2013, 01:18 PM   #4
mad_sb
Drives: 2013 Asphalt FR-S
You can always start by checking where your ARF's are now... the ecu reports wide range sensor data via OBDII. Also check your long and short term fuel trims. And honestly, this is a good idea anyway. You can us torque a supported Bluetooth obdii adapter if you don't already have something to log with.
Then add the pipe and check again... if it is appreciably richer then you can choose an intake that is known the lean out the afr some.
If your trying to choose parts that gain performance without requiring a tune your gonna have to do some serious mixing and matching to get the balance.
Old 03-03-2013, 09:11 PM   #5
victorb
Drives: Black 86
Thank you for your responses. I will be checking my a/f ratio within the week. If I am pretty lean now, I will be getting the front pipe. Also, does anyone know the exact +/- values of thee stock trims, af ratios?
Thanks!
Old 03-03-2013, 09:58 PM   #6
mad_sb
trims are going to vary.. there are 3 or 4 ranges for long term trims (idle, low medium, and high load) long term trims need to be figured into the afr readings. you will see 14.7 in closed loop, open loop will vary but ideally you want to see between 13 and 12.5 under open loop.
Mine seemed to run a bit lean from the factory... It stacked up long term trims between +5% and +10% and ran 13.2 open loop thorugh the midrange tapering to 12.1 and richer by 6500.
Old 03-03-2013, 11:30 PM   #7
victorb
Drives: Black 86
Appreciate the information you gave. really nice of you guys. I will be downloading the torque software, I have an elm obd2 connector. I hope it works. =)
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
