Old 02-27-2013, 01:18 PM   #1
jlu
jlu's Avatar
Drives: Asphalt AT FR-S
Burning smell when front defrost is turned on
Is anyone else getting a strong burning smell when they turn their front defrost on? I've got ~4K miles so I'm pretty sure it's not the normal break-in burning smell.
jlu is offline   Reply With Quote
Old 02-27-2013, 01:39 PM   #2
SupraRon
SupraRon's Avatar
Drives: Raven 6AT
I have noticed this a couple times, but it seems to have subsided in the last 2 weeks. Still monitoring it though.
The fun has returned!!
Morimoto Mini H1 HID conversion
SupraRon is offline   Reply With Quote
Old 02-27-2013, 02:48 PM   #3
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Possibility?
http://www.ft86club.com/forums/showthread.php?t=26197
I get a burning smell through my HVAC from this if the car is not moving (until it burns off).
Chimpo is offline   Reply With Quote
Old 02-28-2013, 07:00 PM   #4
ftc~brz
Done
Drives: WRB BRZ
mine had smelled like burning rubber....haven't smelled it since it was in for new fuel pump. Crickets are back after 1 week so I can only imagine the unidentified burning smell will also return. (I don't think they are related at all) just odds of reoccurring issues runs high. =)
ftc~brz is offline   Reply With Quote
Old 03-01-2013, 01:14 AM   #5
ft_sjo
Drives: GT86
Yup, I have it. I think its the AC rather than the demister particularly.
Old 03-01-2013, 07:01 PM   #6
jlu
jlu's Avatar
Hmmm, haven't turned my AC on in a while - will try and see if that causes the burning smell also.
Old 03-01-2013, 08:40 PM   #7
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
my old tc had a horrible burning smell when i used the defrosters or heat. it was as if something went down through the vents and died/got stuck/whatever. I had to spray a little lysol down into the vent once in a while with the fans on to make it smell better.
abutterman is offline   Reply With Quote
Old 03-01-2013, 08:55 PM   #8
whtchocla7e
Drives: 2013 FR-S Hot Lava
Yeah, I get a smell when using the defroster or the defogger... so pretty much every day..
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 03-03-2013, 04:36 PM   #9
jlu
jlu's Avatar
I got it with the AC also - think I'll ask the service department guys to take a look when I take it in for 5000 mile service.
Old 03-03-2013, 06:09 PM   #10
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Keep in mind if any oil is spilled even a little drop like let's say around the filler cap it could run down to the exhaust manifold after heating up and it takes quite a bit to fully burn off synthetic oil. Had fun chasing leaks on my sw20 I had one that was a very slight drip from the turbo charger oil return line it was only a droplet but it would pool heat up after a drive and drip onto the down pipe. I would park let it cool and then heat back up and drip after a drive keep in mind turbos also generate more heat than an n/a engine.
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-03-2013, 06:28 PM   #11
86KEEBS
DRIFT
Drives: Raven FRS 6mt
I also noticed a burning rubber smell with the heat on. Only noticed it a couple of times yesterday while stopped at a red light. Drove it today with no smell. Its not from oil or any other fluid as far as I can tell (no leaks) It is a burning rubber smell. Not as bad as a burn out, but not normal smelling. It is coming out of the vents with the heat on. Im guessing blower motor problem.. If it gets any worse I will be digging into it myself. I HATE dealerships! They work quick, not properly. I work in a shop and have seen some brutal dealship work!
86KEEBS is offline   Reply With Quote
Old 03-03-2013, 06:31 PM   #12
Touge Monster
How many miles??? You would be surprised how many different burning smells a brand new car will generate.
Old 03-03-2013, 07:53 PM   #13
86KEEBS
DRIFT
6000 kms
Old 03-03-2013, 08:01 PM   #14
SVThis
SVThis's Avatar
Drives: Scion FRS
Originally Posted by Chimpo View Post
Possibility?
I think it's a good possibility
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 04:56 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
Exhaust build up/ burning oil Bu-Tang Issues | Warranty | Recalls / TSB 7 04-04-2013 12:51 PM
Burning oil smell at idle after car warms up chris240 Issues | Warranty | Recalls / TSB 3 02-11-2013 12:33 AM
Burning oil? N/A Synack Issues | Warranty | Recalls / TSB 11 11-08-2012 06:14 PM
