Old 02-27-2013, 01:05 AM   #1
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
What happened to the Works drop-in air filter thread???
Anyone know?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline
Old 02-27-2013, 01:17 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
will post a new one within the week
86_ZN6 is offline
Old 02-27-2013, 01:20 AM   #3
zoomzoomers
Did the last one get closed down? If so, why?
Old 02-27-2013, 01:21 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
the thread was getting crazy. time for a new one
86_ZN6 is offline
Old 02-27-2013, 01:22 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So the offer for a filter to be used for an independent dyno stands?
Sportsguy83 is offline
Old 02-27-2013, 01:25 AM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
yes it does. with the conditions that a dynapack is to be used
86_ZN6 is offline
Old 02-27-2013, 07:58 AM   #7
ThatManAnt
Drives: Whiteout FR-S 6spd
I was wondering that, did someone still not get a legit dyno sheet up?
ThatManAnt is offline
Old 02-27-2013, 08:01 AM   #8
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
I sent you a couple PM's and email -
BRZGrincherhood
Zgrinch is offline
Old 02-27-2013, 08:04 AM   #9
ft_sjo
Drives: GT86
Why set that constraint? Surely any dyno can show a percentage increase before and after. The actual numbers are worthless as none of these chassis dynos are considered calibration devices.
ft_sjo is offline
Old 02-27-2013, 08:39 AM   #10
Sargy
Long Distance Driver
Sargy's Avatar
edit
Sargy is offline
Old 02-27-2013, 08:52 AM   #11
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Dont dynapacks run high, mustangs low, and jets seem to be the "standard"?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 02-27-2013, 08:56 AM   #12
xjohnx
Grip>Slip
xjohnx's Avatar
I'd be more than happy to pick up an hour of dyno time to compare the works, stock and K&N filters(I already have the stock and K&N panel filters), but my local dyno is a dynojet.
I'm running E85, nameless over/downpipe with high flow cat and helmhotz, in addition to their axleback. Latest virtual dynos (which match up closely with the local dyno) show just over 200whp.
xjohnx is offline
Old 02-27-2013, 09:06 AM   #13
AllDayJonRay
Drives: 2013 Ultramarine FR-S
^^^This
Did he seriously have that thread closed on purpose to drive the people away who are asking questions he doesn't want to answer?
Are people really not seeing how this guy is shady?
Why the testing constraint? I have a hunch. The gain from a filter is always going to be a function of a percentage increase in power. And when you consider that dynapacks tend to give results approximately 10% higher than a dynojet, the same % power increase will result in more hp gained on a dynapack.
He's clearly worried about test results. He doesn't believe that his filter will outperform the others. He's worried that it's only going to perform on par with the rest, which isn't a bad thing. I'm sure he'd still sell a ton of filters. He just wouldn't be able to post "10+ hp gain" to market his filter.
Yes, and this supports my 'hunch'. If the same exact test (same care, same day, same time, etc) on a mustang dyno and a dynapack, and there was a 5% gain in power, there would be approx. a 2hp difference in the gains seen between the two.
AllDayJonRay is offline
Old 02-27-2013, 09:29 AM   #14
vtmike
vtmike's Avatar
Drives: Scion FR-S
I wouldn't be surprised to see the next condition be run the works filter first and let the oil temp get high enough and immediately run the stock filter. Then take the highest run for the works filter and the lowest for the stock one.
Sent from my Galaxy Nexus using Tapatalk 2
vtmike is offline
WORKS Resonated AB and Drop in filter phenom86 Engine, Exhaust, Transmission 90 02-28-2013 08:44 PM
WORKS High-Flow Drop-In Filter ~ +10 HP Gains 86_ZN6 Engine, Exhaust, Bolt-Ons 354 02-26-2013 08:37 PM
FS: K&N Drop-in Filter DookDookDGM Engine, Exhaust, Bolt-Ons 4 01-19-2013 01:45 AM
WORKS Resonated AB and Drop in filter phenom86 Southern California 21 11-05-2012 12:27 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
