Old 02-19-2013, 09:25 PM   #1
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
Keeping the OEM radio harness intact
Hi I know a lot of people are happy to cut into the OEM head unit harness, but I'm not. I like to keep it original. And I'm looking for both the male and female connectors to make my own harnesses. I'm half way there.
Some reasons for cutting into it your harness:
-Aftermarket amplifier install
-Aftermarket head unit install
-Aftermarket rear camera install
-Trick the head-unit that vehicle is not moving for gps and dialing options
-Trick the head-unit that the hand brake is engaged for watching movies on the go
As many of you already know from reading the wiring manual there are 4 connectors of interest:
http://www.ft86club.com/forums/showt...=wiring+manual
D11: only e-brake is wired to it, but has the potential to wire a rear camera that will engage when the car is in reverse.
D12: Has a VSS wire (gps/phone trick) and mic and aux wires among other things
D13: Basically the rear speaker harness
D14: Basically the front speakers, power and accesory power harness.
I've found that you can buy the male and female connectors for D13 and D14 pre-wired. They are listed as Metra 70-1761 and Metra 71-1761. They are for sale on amazon. See metraonline.com
I'm looking for connectors D11 and D12 pre-wired both male and female so I can make my own harnesses to add a rear camera and bypass the vss and e-brake for the head unit without splicing original wires.
Anybody knows where I can get them or who makes them? Thanks.
AlexTheGreek is offline   Reply With Quote
The Following User Says Thank You to AlexTheGreek For This Useful Post:
woode (01-01-2014)
Old 02-19-2013, 09:37 PM   #2
AlexTheGreek
Here is D13 and D14 (rear and front speaker harnesses respectively):
Last edited by AlexTheGreek; 02-19-2013 at 09:40 PM. Reason: Adding more information to clear things up
Old 02-19-2013, 09:39 PM   #3
AlexTheGreek
Here is D11 (parking brake and potential for rear camera)
Last edited by AlexTheGreek; 02-19-2013 at 09:39 PM. Reason: Adding more information
Old 02-19-2013, 09:42 PM   #4
AlexTheGreek
Here is D12 (VSS/AUX/MIC/etc...):
Old 02-19-2013, 09:50 PM   #5
AlexTheGreek
And finally here is the general cluster-f of wires you can expect to see after pulling the head unit (by pulling the plastic cover off and removing 4 10mm bolts)
There is at least another 4 connectors going to the damn radio. I didn't even bother going into detail about them but I'm sure the wiring diagram has it covered if you're planning on swapping heads and need everything re-connected.
Old 02-19-2013, 10:30 PM   #6
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
I'm not sure about the 28 pin connector, but svxdc sells an adapter for the 16 pin connector you were talking about.
http://ae64.com/Rear-camera-16-pin.htm
http://ae64.com/Ordering.htm
Is that the kind of part you were looking for?
rupert is offline   Reply With Quote
Old 02-19-2013, 10:34 PM   #7
Suffa
Drives: Black GTS
Can you give me a name or a picture of the tool you use to push the wires into the back of the harness? I saw a guy using one and it looks like a sharp pen tip type of thing. No idea what its called though.
Suffa is offline   Reply With Quote
Old 02-20-2013, 06:57 AM   #8
AlexTheGreek
So basically you're implying that you can terminate wires with a pin and then push them into the back of the back of connector D11 for the rear camera?
avg (01-31-2016)
Old 02-20-2013, 09:45 AM   #9
Suffa
Drives: Black GTS
That or wiring a new harness. Just don't know what the tool is called.
When I was watching the guy doing the harness work on my previous car audio build that's how he wired into the harnesses. Strip the wire abit, put some pin end on it and push it into the harness with some hook tool.
Old 02-21-2013, 08:51 AM   #10
Paragon
Guest
Posts: n/a
Is the brz harness the same as the frs?
Old 02-21-2013, 09:11 AM   #11
AlexTheGreek
To answer that I would research the radio and try to get a pic of the back of them.
The BRZ radio is FA601US and it looks like this:
Old 02-21-2013, 05:54 PM   #12
2forme
The antenna adapter I use is Metra 40LX11
Old 02-21-2013, 07:49 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
Same, works great. make sure you connect it to the blue remote wire though for power. I've got everything wired up and installed, but the stupid amazon seller shipped my bypass signature required without notifying me, so i have to go to the post office tomorrow to get it, yank it out of my dash and install the bypass. so far i like it though. The display is nice, sound is great, very responsive. Being able to have Waze on my head unit is great.
The Following User Says Thank You to xjohnx For This Useful Post:
2forme (02-21-2013)
Old 02-23-2013, 08:33 AM   #14
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Do they make an adapter for the wiring harness at the factory amp? I'm hoping I can just pull the plug and use an adapter to connect it to my DSP and bypass the factory amp.
Skippman is offline   Reply With Quote
Anyone interested in double din dash kit with plug and play harness for new Radio? Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 35 10-28-2014 09:16 AM
BRZ Radio Breakout Harness and/or Pins and Sockets nquillen Electronics | Audio | NAV | Infotainment 4 06-22-2014 11:40 PM
Keeping Your Car Clean on Trips GhostofAkina Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 24 12-28-2012 12:20 AM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 12:24 PM
Lowering gear, AND keeping comfortable MarkMash Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-17-2012 03:12 PM
