Old 02-19-2013, 01:36 PM   #1
xjohnx
Grip>Slip
xjohnx's Avatar
Which harnesses for aftermarket head unit in BRZ?
Does anyone know what brand/part # harnesses work for swapping the head unit on a BRZ? I know some other recent subaru's use the same navi, so it's probably the same harness, but can't find the info after a quick search.
Old 02-19-2013, 08:27 PM   #2
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
I just raised a post about this:
http://www.ft86club.com/forums/showt...harness+intact
You can buy metra 70-1761 and 71-1761 to make harnesses. search for them on amazon and check out metraonline.com
AlexTheGreek is offline   Reply With Quote
Old 02-21-2013, 07:51 AM   #3
Paragon
Guest
Posts: n/a
Do you know if the brz and frs use the same harnesses?
Old 02-21-2013, 07:54 AM   #4
2forme
Yes, the BRZ uses the standard toyota harness for the speakers and power. You will need an antenna adapter to use the AM/FM antenna. The part number escapes me, but I will know later as I have to pick up another one at my audio shop.
Old 02-26-2013, 08:06 AM   #5
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
I have a question for you that work with audio, I want a pioneer for my frs but I want the mic and hand free capabilities to stay good like now. Also I will like to know if there is a wiring harness to install the radio w/o cuting wires.
Is that available?
kombatlion is offline   Reply With Quote
Old 02-26-2013, 08:13 AM   #6
2forme
Is that available?
Most pioneers come with a microphone that you can run up to your visor and what not. Look for a standard toyota wiring harness made by metra. Also get the lexus antenna adapter made by metra. You could literally wire everything up on a table, and just plug and play into the stock harnesses.
Old 02-26-2013, 08:24 AM   #7
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
I will order the Pioneer SPH-DA100 AppRadio 2, comes w/ free harness, lexus antena and the metal arms to attach to the car!! from crutchfield.com WOW!!! Thanks 2forme
OEM mic with aftermarket head unit phenom86 Electronics | Audio | NAV | Infotainment 13 05-09-2013 11:20 PM
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question daforce007 Electronics | Audio | NAV | Infotainment 13 04-14-2013 04:42 PM
FRS aftermarket head unit installation - wiring MindtheGap Electronics | Audio | NAV | Infotainment 35 01-14-2013 09:00 PM
Fitting the radio plug into aftermarket head unit GC GTS Aero Kit Electronics | Audio | NAV | Infotainment 1 10-29-2012 05:41 AM
Best aftermarket head unit mounting kit? TRBO2NR Electronics | Audio | NAV | Infotainment 1 10-13-2012 02:21 AM
