Old 02-18-2013, 07:47 AM   #1
Number 6
Drives: Limited 2013 Pearl White - Manual
Few Questions for all you BRZ brainiacs out there.
I have 2013 White BRZ 6 sp.
I've noticed a few idiosyncrasies with the car and thought maybe some of you could help with answers to these questions.
I have use the search function but couldn't find these answers.
1. When idling with the air cond off, the tach sticks at 650 and doesn't move (ok, that's good). But when I turn the air cond on
the tach will move up to 750, and then, slowly return to 650 in 5 secs. Then about 10-15 secs later it will do it all over again
and again and again.
Why would the air cond compressor keep cycling on and off within 15 secend periods?
2. When using a USB thumb drive to play music thru the head unit, it seems like a folder (in the thumb drive) can't have
more then 255 songs attach. One of my folders had 300 songs and I couldn't see more then 255 on the display, so I moved the
other 45 songs to another folder and then I could see them, is that what everybody understands?
3. My previous cars had been German or Chrysler, they have a thing whereas you push the turning indicator stalk up or down
for a sec and the turning indicator would automatically blink 3 times. This is great for lane changing without having to hold the lever.
Is there any blinker plug-in I can buy that will help the car do this?
4. When using the blue tooth phone there didn't seem to be a Mute button... is there no Mute button?
5. Most other cars I've had.. the radio/phone and window buttons stay active for short time after the car is turned off, but on the BRZ
everything dies immediately... is this adjustable?
6. Is there a plug-in tool I can buy so that I can change the time the lights stay on, and which doors auto unlock, without having the dealer
do this for me.
7. The correct way to close the Hood..... drop it from 12" or press it closed?
8. If you have the auto headlights on and you turn the car off, but don't get out, will the lights just stay on?
sub-question: if you do get out, but had popped the trunk from the button on the dash, will the lights stay until you close the trunk?
I know this is a lot of questions, but would appreciate any answers to any of these.
Thanks for any help.
Number 6 is offline   Reply With Quote
Old 02-18-2013, 08:16 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
1. Normal in all cars
2. Not ure, I use xm and an iPod.
3. Lookup "tap turn"
4. Not that I've noticed. The phones mute button works though.
5. Don't think so. Japanese cars don't tend to do that except for luxury cars.
6. The doors you can do yourself. There's a DIY in here somewhere. Not sure about the lights.
7. Drop it, it's aluminum so pushing it could cause it to dent. S2000s are the same way. 6-9" should be fine though.
8. Yes and yes from what my brain recalls at the moment. Trunk is definitely yes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-18-2013, 08:37 AM   #3
infinite012
Drives: 13 DGM BRZ Ltd
1. You must be new to 4 cylinder cars. This is normal.
2. Probably a software issue.
3. One touch turn signal. Google.
4. Power button.
5. That sounds dumb. I've never sat in my car just listening to music, staring at my window buttons...
6. 555 timer?
7. Slam that sucker down.
8. I hate the auto headlight feature. I know when it's dark.
infinite012 is offline   Reply With Quote
Old 02-18-2013, 09:23 AM   #4
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
To elaborate on what the others wrote:
  1. Don't worry about it.
  2. http://www.ft86club.com/forums/showthread.php?t=10737
  3. http://www.ft86club.com/forums/showthread.php?p=363333
  4. Not that I'm aware of (http://www.ft86club.com/forums/showp...85&postcount=6)
  5. Dunno if a radio timeout is possible, but the windows still work after shut off (until you open the door, or after a timeout - reportedly 45 seconds).
  6. Dunno.
  7. I drop it 9-12".
  8. Yep (AFAIK).
Deslock is offline   Reply With Quote
Old 02-18-2013, 03:58 PM   #5
Z3D
Here is a cool DIY/Build info for the OTTS!
http://e31wiki.org/wiki/One-touch_turn_signal_module
Z3D is offline   Reply With Quote
Old 02-18-2013, 04:16 PM   #6
infinite012
Seriously, if you just google search one touch turn signal, there's already a relay replacement that allows this, is customizable (as far as how many auto blinks), and is compatible with LED bulbs (no hyper flash). The cost is up there, but if it's worth it to you, then get it.
Old 02-18-2013, 04:29 PM   #7
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
For issue 2 (USB), it's not a coincidence that the limit is 255. It's the same as the mpg being limited to 127. Basically when programming software for the radio or gauge cluster, you pretty much get maxed out by how many bits you decide to use in your hardware. The more bits, the more memory the more processing power, etc... the more money. So basically, 255 is 8 bit and 127 is 7 bit. It's just a natural limit of computers and they cheaped out. In the case of the USB, it can be probably be fixed with new code (new firmware release), in the case of the gauge cluster, I doubt it.
AlexTheGreek is offline   Reply With Quote
Old 02-18-2013, 04:37 PM   #8
I'm guessing you don't have kids you have to wait for in a parking lot for after-school activities. I do this all the time....
I agree with the OP this is one of those things I found odd when the 86 didn't do it. This is the first car I've owned in 20 years that didn't do this until the door was opened, and I'm not known for buying luxury cars.
Old 02-18-2013, 04:59 PM   #9
infinite012
Correct.
I guess I'm just used to Subarus not having this feature. Didn't have it in my 05 WRX, didn't have it in my 08 STI, don't have it in the 13 BRZ. Doesn't bother me, though. Maybe there's a way to wire up a relay to keep feeding the headunit power until the door is opened.
Old 02-18-2013, 05:11 PM   #10
Turbowned
Turbowned's Avatar
Praise jeebus, I love the one touch turn signal! One of my favorite things about German cars. Now if only we could get automatic windshield wipers. I think those are the only two features the BRZ doesn't have that I'd miss from having my S4.
Old 02-18-2013, 11:54 PM   #11
Number 6
Thanks Dave, I can use that info.
Old 02-19-2013, 08:25 AM   #12
...Doesn't bother me, though. ...
Yea, not a big deal to me either, I was just surprised the first time it didn't work. No big deal to leave the ignition on if I want to use the electronics.
Old 02-19-2013, 09:22 AM   #13
infinite012
http://www.webelectricproducts.com/ots/toyota/ots2t.htm
I haven't looked to see if we have the 81980-* turn signal relay, but this should be the replacement that will give you auto blink and LED compatibility.
Old 02-19-2013, 03:57 PM   #14
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Why can't the BRZ have all the features, in total, that all the other cars?
Could it be Cost? Weight?
BRZfan is offline   Reply With Quote
A Few Questions for STX Areddi Tracking / Autocross / HPDE / Drifting 10 01-04-2013 09:22 PM
two questions Jeong Scion FR-S / Toyota 86 GT86 General Forum 13 11-26-2012 08:37 AM
Ask more questions ... Maik L Scion FR-S / Toyota 86 GT86 General Forum 9 11-17-2012 01:14 AM
FR-S NAV Questions Dan86 Electronics | Audio | NAV | Infotainment 6 07-01-2012 02:24 PM
Questions Do Boy Engine, Exhaust, Transmission 4 06-22-2012 02:33 PM
