| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: -
Scion FRS or Sub BRZ have auto daylight?
Hi, I want to know if BRZ or FRS have automatic day light? I dont know if this are the good term because im french. But, my parent have automatic light in buick rendez vous and gmc sierra 2500hd 2005, and my sister dont have the automatic light in this kio rio 2012.
Envoyé depuis mon SGH-I747M avec Tapatalk |
Winter is Coming
Drives: GBS BRZ
The BRZ has day running LED lights and also auto-on headlights, as in they turn on automatically when it gets dark out. There is a setting on the blinker/light stalk.
I have no idea about the Canadian version though. As for the Scion, I have no idea. |
#3 | |
I Love custom Turbo kits
Drives: Limited BRZ
BRZ and FRS both have DRL daytime running lights. BRZ is the only one to have automatic lights, meaning they will turn on automatically when it's dark enough. Sent from my HTC One X using Tapatalk 2
Drives: TBD
Did your sister buy her car somewhere other than Canada? Because I am 99% certain that all Canadian cars must by law have automatic DRLs.
Drives: '13 Ultramarine
All cars in Canada are required to have daytime running lights as far as I know. I think this has been law since 1989 or so. I believe the OP is referring to auto-on headlights that come on at dusk. I can't say on the BRZ limited or sport tech, but the FR-S does not have this feature.
Drives: TBD
Could be, but "automatic day light" to me means DRLs...
X Rated
Drives: 2017 BRZ Series.Yellow
He didn't say automatic day lights, he said automatic lights, as in the car will automatically turn on all lights when it is dark enough. All cars are required to have daytime running headlights, but automatic lights for night is not required.
My mother's Volkswagen New Beetle also did not have automatic full lights for night, you had to switch them over manually. It's mostly a manufacturer thing, dependent on who you go to.
Drives: Brz
What I REALLY want with my BRZ is to have the LED "ring" on as the daytime running lights and automatically turn on the headlights when dark. But I don't think that's possible. Or is it?
Drives: Subaru BRZ Limited
I wish that was possible too, but it's not. If it's in "auto" then only the lower LED day time lights are on (if it's not dark out). I sometimes will put it to the "parking mode" during the day just to have the lower LED's and the LED "ring" running at the same time.
#10 | |
Pavement Grey
Just to clarify, Autoheadlights are NOT DRL. DRL or daytime running lights is an always on light but is at low intensity. Supposedly easier to see in the daytime. Its a requirement in Canada since I think 1992, so all Canadian spec cars have it. It can be a part of the headlights, turn signals, high beams or a separate light/lighting strip (most cars nowadays are using a separate LED strip for the DRL). It does NOT turn on the taillights you CAN drive at night with just the DRL, but you'll notice that the car's taillights are not on and the headlight/front lighting is going to be pretty dim. Autoheadlights automatically activate the headlights/taillights when its dark enough outside. You just set the lighting stalk/switch/whatever to "auto" and you pretty much never have to touch that ever again. So get in, turn on car and go. Everything should be lit up at night. I think they have a set delay when you turn off the car. it doesn't deactivate right away (perhaps this is a per car thing) Of course if you've never had the feature, out of habit you'll always just turn on/off the headlights manually. It was mostly a luxury car feature, but is now getting trickled to as an option for mainstream cars. |
#11 |
Drives: TBD
#12 | |
Drives: TBD
#13 |
Op is French Canadian...sometimes things get lost in the translation. I'm pretty confident they're referring to auto-on headlights, not DRL.
#14 |
Yeah it's kind of annoying that the ring is not the day time running lights. It looks so nice, but I will assume that the light output is not high enough for DRLs.
| Rmiller auto sema scion frs | nixeighty6 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 11-01-2012 09:47 PM |
| LED Daylight Bulbs in So CAL | Zoomryder | Southern California | 12 | 09-28-2012 03:24 PM |
| HID for Daylight Running | Zoomryder | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-21-2012 06:47 PM |
| Navigation in daylight | zex | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-04-2012 11:47 PM |
