Old 02-12-2013, 12:39 PM   #1
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Feasible light weighting.
I've come to the conclusion that at this point I do not want to force induce my BRZ... But I still want to increase its performance. I was looking for some assistance in determining the best method for light weighting that's not going to turn her into a NVH nightmare.
I was thinking along the lines of:
Rotational:
Perrin (or other) pulley, -3lbs~
Light weight flywheel, 4-5lbs~
Clutch 300-400tq 4-5lbs~
Carbon fiber drive shaft from RSD 8lbs~
Weds sport tc105n 17x8.5 (if I can find them) -5lbs~ each
Static:
Siebon carbon fiber:
Roof (-?lbs)
Hood (-0.2lbs)
Front fenders (-?lbs)
Trunk (-5lbs)
OEM wing (-?lbs)
Single pipe exhaust(saw one but don't know who made it)
Front control arm braces -3.5lbs
If you can add in any of the weight differences I'm missing or can think of some other good ways to drop weight that's feasible for a daily driver, please give your 2 cents.
Thank you for your help.
Adeets is offline   Reply With Quote
Old 02-12-2013, 01:33 PM   #2
Frostyman
Drives: 2013 Raven FRS
skip the siebon stuff, unless you have the money for big dollar dry carbon. The wet carbon actually weighs more than OEM pieces in some cases.
Frostyman is offline   Reply With Quote
Old 02-12-2013, 01:55 PM   #3
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
light weight battery
mechaghost is offline   Reply With Quote
Old 02-12-2013, 01:57 PM   #4
Ingen
Drives: Ultramarine FR-S 6MT
Spare tire and tool kit
trunk mat if you have one
battery
I would skip all the carbon fiber ambition in favor of the above mentioned. You'll save more just with the battery than with every panel in carbon fiber.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-12-2013, 01:57 PM   #5
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Beatrush front and rear beam braces.
http://www.rallysportdirect.com/Beat...ont-Beam-Brace
illmatic is offline   Reply With Quote
Old 02-12-2013, 02:07 PM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
This:
http://www.ft86club.com/forums/showthread.php?t=13378
Old 02-12-2013, 02:13 PM   #7
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I did an 11lb Braille battery and deleted the trunk junk. Saved roughly 20lbs off the mid-front and about twice that in the rear. Could save a good chunk more by chucking the back seat and draining out some of the washer fluid in the nose of the car but as-is it feels just a little bit sharper than before with zero livability impact so I'm happy.
Wish I had done lighter-than-stock 17 inch wheels & tires instead of going for 18inch Ultraleggeras. Although they weigh about the same as the stock 17s including rubber (net), IMO you can really feel the difference of lighter & heavier wheel weight when turning in and accelerating.
Beyond wheels/tires, battery, and trunk junk delete you're getting into lower ROI, high $$$ and high NVH territory IMO. The stock seats are so nice they'd be a shame to chuck out. Maybe a lighter exhaust would be worthwhile depending on price, amd the sound is nice but you did say 'performance'.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 02-12-2013, 02:18 PM   #8
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by ultra View Post
And the stock seats are so nice they'd be a shame to chuck out.
Im contemplating tossing mine because I need the head room. Im 6'4" and cannot wear a helmet without taking out the roof lining.
supramkivtt2jz is offline   Reply With Quote
Old 02-12-2013, 05:11 PM   #9
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
the car is pretty light as it is, to make it fast you jut have to focus on suspension and the best mod of all time, driver mod.
power adding wont make as huge of a difference as suspension on this car IMO.
nothing will make you faster than seat time and knowledge. period.
Jive Turkey is offline   Reply With Quote
Old 02-12-2013, 05:45 PM   #10
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
The battery I have for my Miata that I use for autocrossing weighs 1.5 lbs. That's 28 lbs of weight reduction vs the stock BRZ battery. The junk in the trunk is worth another 31 lbs. My 17x7 Kosei K1 TS wheels are 6 lbs lighter per corner than stock, for another 24 lbs of weight reduction. The Nameless muffler delete I put on was 23 lbs lighter than the stock muffler.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 02-12-2013, 05:50 PM   #11
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
A 1.5lb battery? I want!
Anthonytpt is offline   Reply With Quote
Old 02-12-2013, 05:51 PM   #12
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
This. Li-Iron (Lithium Iron Phosphate) battery can save you an easy 25 pounds for fairly short money (not Li-Ion). In the front of the car up high. I wouldn't waste my time with Braille and the likes. Old tech and not that much cheaper considering they are 3x the weight.
Headers and exhaust might save you on weight too depending on your choice. I plan to make my own rear seat deletes with some plastic pins and fabric, should save another 20 lbs including all the seat belt hardware back there.
industrial is offline   Reply With Quote
Old 02-12-2013, 06:20 PM   #13
Miniata
[ame="http://www.amazon.com/gp/product/B005FIUJ0S/"]http://www.amazon.com/gp/product/B005FIUJ0S/[/ame]
Old 02-12-2013, 06:39 PM   #14
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
How many cranking amps?
Thanks
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
FS - Light tinted tail light overlays seven Exterior Parts (Aero, Lighting, Etc.) 0 01-26-2013 10:05 PM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
