Old 02-07-2013, 12:11 PM   #1
Alabang 86
Alabang 86's Avatar
Drives: GT86
1st track day
all in all a blast...
a couple of things
- pulsating brake pedal under hard braking, this needs work right now!
- VCS is the same as full traction control IMO.
- TCS off = most amount of fun.
- stay on the gas to stay away from understeer
- 2nd gear powerslides are more fun than learning how to ride a bike.
- notchiness going from 3rd to 4th, always.
- great seats, position, steering wheel, gearshift.
- Go to the track and push it = priceless
Alabang 86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Alabang 86 For This Useful Post:
Anduz (03-05-2013), LeeMaster (02-07-2013), Sonolin (03-06-2013), ultra (02-07-2013)
Old 02-07-2013, 12:15 PM   #2
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Vids or gtfo. lol.
Glad to hear you had fun-- do you plan to do a street/track build?
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 02-07-2013, 01:57 PM   #3
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
a couple of things
The pulsating under hard braking is your ABS kicking in.
If you get more serious about track days, the first things you should do is upgrade your brake pads, brake fluid to a dot 4 synthetic (Motul RBF600 is great), and good tires make a HUGE difference on these cars. Some Dunlop Direzza Star Spec 2 or Hankook RS3 tires aren't too expensive, and will dramatically improve your lap times If you put some better gear oil in the trans, it might eliminate the notchy shifting.
Track days are more addictive than any drug, and potentially more expensive once you start dumping money into your car, haha
Mark Slide Squad is offline   Reply With Quote
The Following 2 Users Say Thank You to Mark Slide Squad For This Useful Post:
CSG Mike (03-05-2013), dphan (02-07-2013)
Old 02-08-2013, 08:45 AM   #4
invisage
Drives: Thunder Silver 86 GTS
Had my first track day today too! Didnt find the brakes too bad but yeah new tyres are a must! Besides that is there any other things I can look out to help with handeling around those bends?
invisage is offline   Reply With Quote
Old 03-05-2013, 09:34 AM   #5
Alabang 86
Alabang 86's Avatar
Drives: GT86
Originally Posted by Asterisked Accolade View Post
Vids or gtfo. lol.
late reply here, still learning how to use the forum....I'm old.
When I bought it (my 6yo son insisted) I was planning on a stock setup. Now that I spent some time on track. the AMEX has been pulled out.
Nameless is on order. and I'm trying get to the top of the list for a supercharger.
ordered a CF drive shaft before I bought the car but still waiting for it to arrive. takes a little longer when shipping to the Philippines.....
thanks for your comments and advice.
you might be right on the ABS, I did notice the pedal completely locked up hard when I spun and braked hard when moving backwards. Strange sensation. ABS doesn't work in reverse or I had differnt tires moving in different directions?!
but under hard braking everything felt spongy, not ABS intervention. I am waiting for a master cylinder bracket, might help.
What's a good tranny fluid?
I found lots of gas pedal from the Apex was most effective....
Old 03-05-2013, 10:05 AM   #6
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
That is awesome... ABS kicking in is good, but you want to make sure you brake just prior to the ABS kicking in to get max stopping power
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 03-05-2013, 10:13 AM   #7
Alabang 86
Alabang 86's Avatar
Drives: GT86
yes! but I didn't have to fight ABS on the hard braking. I was trying to go-kart it using the slide for more braking. What a blast. Check out Batangas Racing Circuit, for $300/year you can "run what you brung" as much as you want.
...my turn...
Old 03-05-2013, 10:45 AM   #8
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I'm feigning for a track day right now.. god it needs to be April/May already.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 03-06-2013, 10:48 AM   #9
Asterisked Accolade
Oh this is making me car-oused.
Old 03-06-2013, 01:42 PM   #10
Mark Slide Squad
Most likely the brakes felt "spongy" because the factory brake fluid was boiling, and/or your factory brake pads were too hot. The factory items work fine on street, but when pushed to the limits on track, they aren't designed to take the heat ranges of continuous hard braking lap after lap. The master cylinder brace won't do much. That's why I suggested swapping to an aftermarket brake pad like some Project Mu Club Racer pads, they will be fine on street, but on track they will bite MUCH harder than stock, and they won't fade/go mushy like the factory pads do. The brake fluid will have to be changed too so it can handle the extreme temps. That's why I also suggested a DOT4 Synthetic brake fluid like the Motul RBF600. It won't boil over on you, because if the fluid does boil, your brakes basically do nothing, and that's not a good feeling. I tracked my FR-S factory stock at Buttonwillow Raceway last year and the stock pads and fluid were done after several laps. I upgraded pads and fluid and it made a WORLD of difference. Don't waste money on the master cylinder brace. And as I mentioned, different tires will transform the car in a very good way!
The Following User Says Thank You to Mark Slide Squad For This Useful Post:
CSG Mike (03-06-2013)
Old 03-06-2013, 02:51 PM   #11
Stevo22
Stevo22's Avatar
Drives: GR86
Is that you on the Desmosedici in your avatar picture?
Stevo22 is offline   Reply With Quote
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
