Old 02-07-2013, 12:10 PM   #1
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
JDM steering wheel off center after install
After installing my JDM steering wheel it's a few degrees off center. I've tried removing the wheel and repositioning it a few times but it always feel about 1-3 degrees off to the right or left. I'm thinking the splines are not matching the O.E.M steering wheel splines but I’d have to check when I have time. Would this be a easy fix or should I bring it in the shop to have it properly aligned?
iketiak is offline   Reply With Quote
Old 06-25-2013, 01:13 PM   #2
jupillam
jupillam's Avatar
Drives: White out Scion Frs
I have the same problem after replacing with European stalk for fog light....
jupillam is offline   Reply With Quote
Old 06-25-2013, 01:25 PM   #3
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
You have to make sure the wheels are straight and true before removal/install. If they are already straight then it might mean you will have to adjust the steering rack.
Beyer Subaru is offline   Reply With Quote
Old 06-25-2013, 03:09 PM   #4
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
This, I've done this mod in a few Hondas. Always get out abd make sure your tires are perfectly straight or when removing the stock wheel use tape or a marker to put a small mark to line up the new wheel with.
FRSfan111 is offline   Reply With Quote
Old 06-25-2013, 05:16 PM   #5
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
this should be easily avoided by using a 1-2 long strips of painters tape and line up the steering wheel with the column. I would probably put 2 strips about 3 inches apart so that you can properly align the steering wheel after, even if it's turning.
CamryDS is offline   Reply With Quote
Center Arm Rest...Install Scooby South Cosmetic Modification (Interior/Exterior/Lighting) 11 04-03-2013 12:59 PM
steering wheel vibrations fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 17 09-08-2012 05:29 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 10:43 AM
