Old 02-06-2013, 09:50 AM   #1
chappys4life
Drives: 2013 frs
Guys with hids and led drl need input
I am looking at doing led drls and hids. With the led drl's you loose high has that been a issue at all?
Also what way did you do his? Retrofit projector kit or hid kit in existing headlights? What brand did you use?
chappys4life is offline   Reply With Quote
Old 02-06-2013, 11:34 AM   #2
Xdragonxb0i
Drives: ex500r
I used eBay HID. For 35. Was pretty good. But I don't know how long it was last
I also have led DRL. It looks great. But you do lose high beam functionality. If you still want high beams. Then should do HID DRL
Xdragonxb0i is offline   Reply With Quote
Old 02-06-2013, 11:39 AM   #3
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
DDM tuning HIds here.
great price and excellent product
Old 02-06-2013, 11:41 AM   #4
chappys4life
Drives: 2013 frs
Hid drl is that an option?
Old 02-06-2013, 05:05 PM   #5
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
once u have the HID on your low beams. u wont really need for the High Beam. HID low beam light output is enough. just get a DRL LED. if u still wants the high beam function, using HID kit on high beam is just a waste of $$$.. just get a regular high beam bulb with your choice of color.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 02-06-2013, 09:09 PM   #6
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Got mine from here. Really legit and great quailty plus 3 year warranty
http://www.distantxtremes.com/fr-s-l...cessories.html
rhood168 is offline   Reply With Quote
Old 02-07-2013, 11:11 AM   #7
CharlieChaos
Drives: FRS
I went with True Street Industries and did the HID the LED Switch backs and the rest of the LED interior exterior. I have had 0 issues at night and have had a few friends with FRS grab the lights after seeing them.
You can talk to Lisa@TrueStreetIndustries on the forums here
_____________________________________________
http://genometuning.com
http://www.BlackHandGaming.com
CharlieChaos is offline   Reply With Quote
Old 02-07-2013, 01:51 PM   #8
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I was on the same page. I wanted high beams. But I realized I never used them. LEDS are the way to go
Chen is offline   Reply With Quote
Old 02-07-2013, 02:06 PM   #9
CaptainSlow
CaptainSlow's Avatar
I will be going HID lows (6000K kit from Distant Xtremes) and LED DRLs. Obviously can't give an opinion either way, but I heard enough good things about that setup that I went that direction.
One thing I don't know is how easy it is to change the high beam bulb...if it's fairly simple, it might be worth it to just swap out the bulbs if you plan on doing a long night driving stint out in the wilderness
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 02-21-2013, 09:15 PM   #10
Vokalharmony
Vokalharmony's Avatar
Drives: 2013 scion FRS
HID 8000k with 55w ballast
Bought these and absolutely love them. Got them with free shipping all plug and play directly into the factory plugs. http://www.hidextra.com/h11/8000k/
Vokalharmony is offline   Reply With Quote
Old 02-21-2013, 09:19 PM   #11
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
The high beams makes a damn big difference on the highway even with hids in the low beam!!
Rayme is offline   Reply With Quote
Old 02-21-2013, 11:22 PM   #12
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Im a little confused... I have HID and LED drl and i still have high beam.
chenshuo is offline   Reply With Quote
Old 02-21-2013, 11:40 PM   #13
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You have a BRZ i assume he is talking about the FR-S
I have 5000k Morimoto HID's from TheRetrofitSource.com and LED DRL's from Concept-Three-LED's, the low beams are good enough for most situations but i find that when its raining and really dark i have trouble seeing. I ordered some 3000k LED DRL bulbs from Concept Three to use as a fog light when in those situations i'll let you guys know how it works.
JoeBoxer is offline   Reply With Quote
Old 02-22-2013, 12:01 PM   #14
F n' A Automotive
F n' A Automotive's Avatar
Drives: 11 STi Sedan
Hey guys, I'd just like to shed some light on the topic from our personal experience. The FRS uses a projector that's strictly low beam, and a DRL that also functions as a high beam. Once you upgrade to HID's in the FRS, you will have brighter headlights that can handle most of the night driving you'll do. LED DRL's in the FRS are another story. They look great, and will still brighten up if you hit the high beam, but at that point, you're basically using them for "signalling" purposes only. The LED DRL's will not be brighter than your headlights as far as night driving functions. Now you are left with another, but more costly option, which is opening up your headlights and replacing the stock FRS projectors with Bixenon projectors, and you'll be left with a great highbeam option. I never recommend HID High beam/DRL's because it is very taxing on the ballasts when flashed constantly to signal other drivers. If you left them off, and only turned them on for extended night driving (almost like headlight use) they are fine to use, though. Please feel free to PM us and we'll answer more questions and set you up with a package!
F n' A Automotive is offline   Reply With Quote
Input FR-S vs 370z krushin FR-S / BRZ vs.... 116 03-19-2014 04:04 PM
Asking for some input on accents JoeBoxer Cosmetic Modification (Interior/Exterior/Lighting) 16 12-18-2012 05:22 PM
Delete driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-15-2012 01:00 AM
TEXAS DRIVERS! Need your input! zaptorque Southwest 23 11-10-2012 08:37 PM
Using AUX input on BeSpoke? DarrenDriven Electronics | Audio | NAV | Infotainment 14 11-02-2012 09:00 PM
