Old 02-03-2013, 02:24 PM   #1
Blake
Drives: Ravin Scion FR-S
Question FR-S Headlights Question
I know this is going to sound really stupid to most people, but I genuinely do not know.
I am looking to buy led running lights for my FR-S. When I go to buy them some say running lights, High Beam; and others say running lights, Low Beam. Now I know the difference between low beam and your high beams. But what do I buy if I want my regular running lights to be LED? I noticed when my running lights are on, the high beams come from the regular headlights. And at night when my regular headlights are on, the high beams come from my running lights.
ALSO, I am about to buy the led white parking lights that switch back to amber when the blinker is on. However, I was wondering about a resister to keep them from hyper blinking. The package I am about to buy on ebay says it comes with both for $59.99. But where does the resister go?
Blake is offline   Reply With Quote
Old 02-03-2013, 02:36 PM   #2
spgrizz22
Drives: Scion FR-S
Wait where are you buying the lights that switch from amber to bright white?
spgrizz22 is offline   Reply With Quote
Old 02-03-2013, 02:39 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Your daytime running lights and high beam are the same bulbs. Does it make sense?
So if you switch your bulbs for LED's, you lose your high beam. Hope this helps.
Rayme is offline   Reply With Quote
Old 02-03-2013, 07:19 PM   #4
Fuzzysmith
Drives: 2013 Firestorm FR-S MT
And the resistor replaces the current flasher relay. Stick your head down by the pedals and look near the steering column. You'll see a rectangular black box that is fastened to the frame.
Fuzzysmith is offline   Reply With Quote
Old 02-03-2013, 07:20 PM   #5
Fuzzysmith
FYII was told that if you swap that relay, you should have LEDs front and back as you will putting a greater load on that relay if you don't.
Old 02-03-2013, 07:27 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
As was said already, you WILL lose high beams.
You can also replace the entire blinker unit with a new one. That way, you won't have to worry about resistors.
eBay...at your own risk.
Old 02-03-2013, 08:55 PM   #7
Blake
So if I buy the running lights that say High Beams, does that mean they can be regular & high beams?
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
(GTA) Headlights jsn711 CANADA 13 12-05-2012 01:27 PM
[Noob Question]Will you be able to swap BRZ and 86 headlights? Slide Cosmetic Modification (Interior/Exterior/Lighting) 41 02-18-2012 01:26 AM
A question regarding xenon headlights Go Mango Scion FR-S / Toyota 86 GT86 General Forum 15 04-14-2010 09:14 PM
